HP Compaq Presario V2000 Notebook Logo
Jaikumar Peddy Posted on Jul 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Presario v2000 Laptop dead.
Presario v2000 Laptop motherboard in not getting power on.only shows charging light.Switch ok,batt.is ok,dc jack is ok. Where is the problem located on board? Plz help me
Anonymous
Level 3:
  • Master 808 Answers
  • Posted on Jul 28, 2010
Anonymous
Master
Level 3:
Answers
808
Questions
0
Helped
142752
Points
1763
Its may be the problem on ur psu or ur motherboard
Presario laptop issue with power indicator light and detecting powers supply
Sounds like your DC Power Jack is bad or broken. The DC Power Jack is where the power cord plugs into the laptop? Most times it get damaged by too much stress on it such as sitting in bed with the laptop, or putting the laptop in the laptop bag with the power cord still plugged in.
Take an ink pen and put it into where the Power Cord normally plugs into the laptop. If the pin inside the DC Jack is loose or wiggles then the jack is probably bad. Sometimes the jack can be completely burned out and you can smell smoke .
If the internal DC Power Jack is loose, you will have totake the laptop apart to repair it. The DC Power Jack is on themotherboard and most times it is soldered to the motherboard. That meansyou will have to desolder the old one and solder a new one in it's place. Sometimes the dc power jack sits in a slot between the bottom case and palmrestwhich hold it in place and has a cable harness that plugs into the motherboard.
2answers
My laptop v2000
possible that the dc power jack is faulty. Worst case is that the motherboard went bad.
1helpful
I need to replace te DC jack P/N PJ-019 in my
almost total disassembly. unsoldering the old jack and soldering new one, like 4 or 5 spots on the jack/motherboard. i just had someone do this for me. found them on craigslist. $45. i had to order the jack from ebay though. it was less than $4
1helpful
2answers
Dc jack is not working, can I still use a docking
I have seen this problem with many laptops.
What has happened is that the power connector on the laptop has loose solder connections and will not trasfer the power through the jack. Either the jack needs to be resoldered on the motherboard or replaced. This is a very intense repair, because the motherboard has to be removed for the repair.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
The prong where I plug in my battery charger broke off in my laptop. What can I do?
This is the DC Power Jack. Aslo known as the DC-IN jack.
You'll have to have it replaced.
IF, this is a reference to a Compaq Presario V2000 Series Notebook PC, (The exact Model Number, is on the bottom of the laptop in a white Service Tag),
the DC Power Jack is soldered directly to the motherboard.
The DC Power jack resembles this one,
http://www.laptopjacks.com/view_part/Compaq-Presario-laptop-power-jack-CQ21325.html
[At the top of the page you can click on the multiview (Three views shown), to enlarge it]
You can see the size of the jack. Not much larger than the AC adapter,
(Charger), plug.
The rectangular dark body of the jack is made of plastic. The metal center pin is riveted to the body.
This is the Maintenance and Service Guide, (Really a Service Manual), for the Compaq Presario V2000 Series Notebook PC's,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=500508&
It's a download page for the Maintenance and Service Guide, from HP Support. (As you know HP bought out Compaq)
Left-click on -
Compaq Presario v2000 Notebook PC, HP Pavilion dv1000 Notebook PC, HP Compaq nx4800 Notebook PC - Maintenance and Service Guide
(Last file in the list)
This is a PDF file. (The computer you are using now has Adobe Reader on it, which uses PDF files)
After you click on the link it may take up to 24 seconds to see the first page. The file is downloading in the background.
(First page usually comes up faster)
After you see the first page, the file may still be downloading. (Blue download progress bar)
I advise letting it fully download, before looking through it.
You may break the download connection otherwise.
This shows you the inside of your laptop. Shows you how various components are removed, and installed.
[Tells you about Static, and how it's harmful to your computer, therefore before diassembling the computer, you should take appropriate measures. ESD wrist s-trap. Price is around $6]
Included this file download link in case you are curious about the inside of your computer.
To repair, or replace, (IN your case it would be replace), the tech has to,
1) Wear an ESD wrist s-trap, and have the alligator clip attached to a good ground source. [Electro Static Discharge]
The human body carries Static electricity. Static wil fry out the delicate hardware components inside a computer. (Laptop or desktop)
Can do it in less than the blink of an eye, and you won't see it, or feel it.
The ESD wrists-trap helps to prevent this. (It works, trust me. IF, you have the alligator clip attached to a good ground source)
A multi-compartment container is used for the various areas the screws come out of, and the various screws. There are over 60 screws, and 12 different types. Some look the same, but they Aren't.
2) The laptop must be Completely disassembled down to the bare motherboard in hand.
No Processor, Ram Memory, Wireless module, Harddrive, Optical drive, (DC/DVD drive), and other hardware components, can be attached to the motherboard.
Bare motherboard.
3) The DC Power Jack, (DC-IN), is unsoldered from the motherboard, using careful desoldering techniques.
The new jack is then soldered in using careful soldering techniques.
(Very few techs are qualified to do this anymore. They just want to replace the motherboard)
4) Then the laptop is reassembled, power sources are attached once more, and the laptop is tested.
2helpful
2answers
Compaq presario C501nr wont charge battery
its in your power jack its a common problem try to check and change.
My compaq presario will not power up (no power). I have swapped and tried a different power supply. No luck
Could be one of a few things. I'm assuming this is a presario laptop, not a desktop.
System needs to be restarted - Remove the battery and let the laptop sit a while (30 minutes). Reinstall battery and plug in power supply and see if it works. If not,
Remove the Battery and see if it is charged up (there are a set of green lights on most compaq laptop batteries with a spot to push to confirm the battery is charged). If it isn't charged, you very likely have a bad DC Jack connector on the laptop motherboard. If you apply pressure to the cord which plugs into your laptop (up and down, side to side) at the spot where the cord is connected (back of the laptop), see if the power light, on the front of the laptop, comes on for second. If it does, you can fix this by buying the DC Jack for your laptop model on ebay ($10) and removing the old connector and installing, soldering in, the new connector. This will require you to take your laptop apart. (note: Search the internet for the service manual for your laptop and this will give step by step directions on how to do this.)
Also, I think they do this at Best Buy (Nerd Herd) if you aren't comfortable doing ($75)
If it's not the DC Jack, it's a problem with the motherboard / CPU / Power Inverter or something else, most likely not worth your time to fix. You could sell the laptop for parts on ebay to recoup as much of your cost as possible, then buy another.
If you are slightly mechanical and are looking for a project and don't need the laptop immediately, you could buy the individual parts and replace piecemeal, based on directions from the service manual. FYI - I've picked up a few laptops for next to nothing and repaired this way {Compaq Evo n620c (CPU / DC Jack), IBM T22 (LCD Screen), Compaq M700 (DC Jack)}.
2answers
Problem
DC-DC board or motherboard. does it boot up from a charged battery (like from another laptop)?
if it works on battery power then i'd look to replace the DC-DC board (its a little board inside the laptop that holds the power jack and a few power-related components)
if it continues to beep even when only on a battery then you should look into a replacement motherboard. and if you have a Compaq V2000, i'd look into a "parts/repair" laptop from eBay or something because that will cost less then just a motherboard.
also the DC-DC board may be built into the motherboard. in that case there is none and the motherboard is the thing you want to replace.
5answers
Compaq Presario V2000 no power new dc jack
I think that this can be rated as solved. If it is not solved please let me know.
Testing dc jack on laptop
You are not supposed to get a short on the power you could take out the power socket and try the test straight to the board.
On a board I have that works using my digital meter on the diode setting I get a reading of 1200 aprox and 190 aprox when the probs are reversed.
If you have a dead short and the power socket is ok then likely there is a resister shorted out or a diode or even a transistor chip on the mainboard.
It should be ok to power up while in bits so long as the cpu fan is running.
Good luck Regards Wayne.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
