Maytag Neptune MAH5500B Front Load Washer Logo
Posted on Jul 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Unbalanced maytag my machine keeps unbalancing ?
dumbgames
Level 2:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 109 Answers
  • Posted on Jul 28, 2010
dumbgames
Expert
Level 2:
Night Owl:
Answers
109
Questions
0
Helped
29354
Points
277
Probably the inetia switch on the top of the tub
I keep getting ul code on maytag bravo mtw6600tq0. I've already replaced the suspension rods. Still getting code during spin cycle.
Your washer is off balance or the load is unbalanced. If uL (unbalanced load) appears in display, the load is out of balance. The washer is running a load-balance correction routine.Sep 25, 2018
Maytag top loading washer goes straight to agitation, won't fill with water.
you may find that the water sensor is not working as it should, unplug the machine take the back off locate the small 5mm pipe going upwards take it off and blow gently into it you should hear a click and one when you release the air, if so then the place you took it from is blocked, clean it out with a pipe cleaner or metal rod replace the pipe and rear panel and run the machine again, try to make Shure that you always fill the machine to its recommended load to prevent unbalanced loads eric
Fisher & Paykel Washing Machine WL80T65CW1 Aquasmart - Machine keeps saying it is unbalanced.
this model is prone for the suspension rods to weaken and cause fault,fit new set of suspension rods
I have a maytag washer i bought in 97. It became unbalanced well my husband fixed it and everytime it goes on the spin cycle it gets unbalanced again and makes a very loud noise
If the washer is truly balances (check with a level to be sure) you might just have an unbalanced load. When filling your machine with laundry, think of the tank as a big circle divided into four pie slices. Make sure you fill each of the four slices evenly. This should help,
2helpful
Unbalanced load stopped machine will not restart why?
On some of the maytag washers when an unbalanced load stops the maching it blows an internal fuse located behind the front panel on some stacking washer and dryer machines and under the counsel on some of the top load machines. ON the top load machines it is recomended that you change the lid switch with the fuse that comes with it.
There are two screws located on each side of the counsel. Remove the two screws and tilt the counsel up and locate the lid switch, fuse assembly. You can check the fuse at this point.
What causes unbalanced signal: on my gas dryer machine the unbalanced signal comes on even when there is no load in the machine.
try leveling the machine. Usually the front "feet" turn, allowing them to be moved up and down. If you have an actual level, this could help.
2answers
Uc code error
uc code means unbalanced condition. My research shows this as being an unbalanced load or a faulty control board.
Make sure your load is balanced, otherwise you may have to replace the control board.
3helpful
Empty washing machine still unbalanced
Lift the Back up by the Top back it has self adjusting legs and do the sam in Front ttech
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
