Maytag Neptune MAH5500B Front Load Washer Logo
Posted on Jul 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Matage neptune mah8700aww purchased five years
Matage neptune mah8700aww purchased five years ago started leaking into my riser drawer . and my dryer mde9700ayw goes caclunk everytime it spins . only five years old for a family of 3 seems a little soon to be having any trouble.
dumbgames
Level 2:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 109 Answers
  • Posted on Jul 28, 2010
dumbgames
Expert
Level 2:
Night Owl:
Answers
109
Questions
0
Helped
29329
Points
277
4 screws takes the front off the washer to find the leak, dryer probably needs drum rollers. If you didnt know maytag went bankrupt for a reason
HOW DO I BUY THE RISER DRAWERS FOR WASHER & DRYER 2 YRS OLD
try these guys , i just bought the parts for a ten years old ariston, but they cover all makes.
http://www.ukwhitegoods.co.uk/
Neptune mah8700aww has a e3 code
The Neptune can sometimes be reset. God knows the repairman for Maytag really needs to get back to work, yet to reset the cpu on your washer/dryer just unplug the unit for 60 seconds. I hope this helps you out.
My husband purchased a Maytag Neptune front load washer model # MAH8700AWW about 5 years ago. The washer works great and we have never had any problems until recently. We just had pergo floors installed in...
you may need to put some anti vibration shock pads under the legs or some two sided tape to put on the feet to help secure it to the floor it may be slipping on the new floor surface
MATAG NEPTUNE WAHER LEAKS FROM FRONT DOOR
hi there,
base on your problem, and other like what you say they changed the seal gasket of the door to avoid the water from spilling or leaking on the front door.
Hope this initial info helps.
We have a Maytag Neptune washer Model # MAH4000 AWW it is leaking from the front at the bottom of door. Water pours out like a water fall when it wants to rinse. Any ideas?
TO ELLIESHIRK, I SEE YOU POSTED YOUR PROBLEM ON MAR. 19, 2009. I HAVE A MATAG NEPTUNE FRONT LOADER WASH MACHINE MODEL #MAH55FLBWW. I AM HAVING THE SAME PROBLEM WITH MY MACHINE LEAKING WATER OUT THE FRONT DOOR. MY WASH MACHINE SEAL LOOKS FINE. IF YOU HAVE FOUND A SOLUTION TO YOUR WASH MACHINE LEAK PROBLEM, PLEASE LET ME KNOW, OK. YOU MAY EMAIL ME AT: [email protected] , MY WASH MACINE IS NOT VERY OLD EITHER 4-5 YEARS IM GUESSING, IT WAS LEFT WITH THE HOUSE I PURCHASED. THANK-YOU FOR YOUR HELP AND TIME. CONNIE
Dryer door will not open
only the washer has a main bearing. the dryer only has bearings in the motor and still would not cost 1,000 to fix. did you door issue get fixed? Joe
3helpful
2answers
Repairing leaking Maytag washing machine
Maytag Appliances are ****!! Don't buy Maytag. Spent $2500.00 in 2005 on Maytag Neptune washer and dryer. They have been nothing but trouble. Washer has water running in tub constantly. Recall on ground and recall on footing. Dryer making loud noise when drying clothes.The Maytag man is dead and gone.
8.8. on Display
Mine had a fried control board. $150.00 for the part, did the work myself. Will not be putting any more money into these Matag Neptune pieces of junk after this. Will buy another brand of washer and dryer.
11helpful
4answers
Maytag Neptune MAH8700AWW Front load
I have a maytag neptune front loader (MAH8700AWW) unless I turn the water off @ the faucet the water continues to run into the washer after the load is done .How can I fix this.
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
