Question about Dictaphone 2740 Desktop Cassette Transcriber / Recorder
Dictaphone MicWiz We use the MicWiz program to setup foot pedals for our remote transcriptionists to use on our GE Centricity system. For the first time, we are experiencing a problem with MicWiz not detecting the USB foot pedal. The USB option is not available (not even grayed out) when we run MicWiz on the transcriptionist PC. Other programs like Express Scribe detect the pedal, but not MicWiz. She is running Windows XP and everything appears normal. Do we need to install some other program or update any of the transcriptionist .dll files? Any help would be greatly appreciated. Thank you, Catherine
    New Friend:
Catherine, did you ever get an answer for your problem with MicWiz? I am a transcriptionist that works from home and they are having problems getting it to recognize my foot pedal (as well as another MT) with the new software. It is recognized by Express Scribe and ever other system we use, but not Merge.
Thank you, Cindy
Posted on Dec 15, 2009
  • Anonymous Dec 15, 2009
    I am sorry, I was not trying to post a solution - just another question. I think I did it incorrectly.
SOURCE:
After mcafee did a recent update my GE Centricity 6.1 no longer works
Hi flatwaterman
I hope you have the GE Centricity 6.1 install disc , because you may need to delete and reinstall the program . Look in the settings of McAfee to unblock the firewall that is preventing your software to run smoothly . If the problem persists , delete and reinstall your software . If it still doesn't work , change your anti virus .
Best regards ,
fanaudi .
May 25, 2011 | Mcafee VirusScan Plus Full Version for PC
My dictaphone is playing super fast. I do not know what is wrong with it. If anyone can help me that would be great. Thx!
Hello make sure the Speed control at front is on center if yes when is hapening make sure that you press the play button on the unit wile this is hapening just unplug the pedal if the problem get fix playing, your unit with out foot control you need a foot pedal replacement if not sounds like a bad motor I'm senting a link for a replacement pedal and a service place in case you need to send your unit to repair http://www.tvps.com/Products/ECS-IN-585-Heavy-Duty-Foot-Pedal---Pre-Owned-IN585__ECS-P-IN-585.aspx
Send an email to service@tvps.com or call (800) 644-9525. Please indicate model, serial and detailed description of problem
Nov 08, 2010 | Dictaphone 1740 Desktop Cassette...
Any function I press on the foot pedal results in a request from the unit to "press conference". What do I do to make this work?
Hello you have your unit set up for Hands free recording Follow the next step
Press and Hold Search and Erase at the same time then you will be and the setup mode press play into you see hands free and press FF to say No then press Pay and press stop to exit.
Jun 23, 2010 | Dictaphone 3750 Desktop Cassette...
Foot pedal does not work for my Dictaphone model 2750 Where can I purchase a replacement
Make sure the foot pedal is plugged into the SIDE of the machine and not the BACK of the machine. I've seen many people make this mistake...
Apr 30, 2010 | Dictaphone 2750 Desktop Cassette...
I am a transcriptionist who is remotely accessing a work computer
I looked a the Infinity IN-USB-1 foot pedal, thanks. I would go out and buy a second foot pedal for home then you can remote your work pc by using the foot pedal from home. Make sure you install the drivers for the foot pedal at your home pc. If this doesnt work, you can always take the pedal back to the store. I figure that If you took away your mouse from your home pc, you could not move your mouse on the work pc. It maybe the same with the pedal. Let me know if it works.
WBTech
Jan 19, 2010 | Computers & Internet
Foot pedal FF or Rewinds when pressing Play
It's possible that there's a broken wire in the cable that connects the foot control to the machine. This usually happens near the plug that plugs into the machine, or by the end that goes into the foot control.
You can usually duplicate it if you put the auto-backspace up a bit and then hold down the play pedal on the foot control. While holding down the play pedal, try moving the cable near the machine or near the foot control in a circular motion. If the machine stops, rewinds or fast forwards, then odds are that the problem is with the cable.
Mar 13, 2009 | Dictaphone 3750 Desktop Cassette...
Dictaphone Expresswriter 2740 Tape Won't Move
The problem is with the capstan motor. More than likely it has developed a 'flat spot' and won't spin up. The clicking noise you hear is the solenoids trying to pull the heads into place, but because the motor isn't turning, it can't pull the heads into place.
Mar 05, 2009 | Dictaphone 2740 Desktop Cassette...
Dictaphone foot pedal
It would be easier/cheaper to buy another foot pedal.
The older style had "leaf" switches in them and they are adjustable from below the foot control. There are 2 screws underneath each switch. Loosen up the one closer to the front of the pedal (just a little) and tighten the one in the back the same amount. This will raise the angle of the switch to make it more sensitive (lighter pressure to activate).
Oct 10, 2008 | Dictaphone Audio Players & Recorders
Pedal problems
If the tape re-winds when you take your foot off the pedal then the auto-rewind switch on the right side of the machine at the back is set to number 3. Move it forward to number 1 or 0. If it really does rewind while your foot is on the pedal then I don't know what is causing that. Sorry.
Jul 07, 2008 | Audio Players & Recorders
Dictaphone 2740 Desktop Cassette Transcriber / Recorder Logo
339 people viewed this question
Top Dictaphone Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Dictaphone Audio Player and Recorder Expert? Answer questions, earn points and help others
