Razor E100 Electric Scooter Logo
Anonymous Posted on Jul 27, 2010
I need instructions on how to replace the rear tire on a razor electric scooter model E100
Anonymous
Level 1:
New Friend:
  • Contributor 38 Answers
  • Posted on Aug 18, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
38
Questions
0
Helped
39667
Points
87
You can't change the tire it is a soild rubber tire molded to the rim. To replace it you have to buy a new rear wheel. Here is a website that sells it.
http://electricscooterparts.com/razore100.html
Razor Scooter ground fOrce go cart wont go
The E100 is a Kick Start scooter, the Rear Wheel has to be Spun for it to start. This scooter will not start from a motionless position.
Could be the battery.
Put the Scooter on a block so the rear tire is raised. Remove the standing plate to reveal the battery compartment.
Charge the Unit completely
1. Using a multimeter measure the voltage across the batteries. If the voltage is below 20 volts batteries are dead - Replace batteries.
2. Now for a running test. Turn the throttle and spin the rear tire to preform a kick start. Still measuring the voltage. If the voltage is Below 20 volts or if the voltage drops quickly batteries are dead - Replace batteries.
3. If the voltage is remaining around 24 volts for a long period - then you could have connector problems, clean and tighten all connectors.
I use a fiberglass electronic cleaning brush, as contact cleaners leave residue that interfere with electrical connections.
See my other posts for E100
How to fix my razor scooter e100?
The control module is simple and can be replaced with only a 24 volt relay without the kick start feature or Brake. If you want the brake then you can use two 24 volt relays still no Kick Start.
For those of you who know electrical, below is circuits I developed to replace the controller. This diagram will also give you a better understanding on the Razor circuit.
NOTE : This is not a schematic diagram of the Razor E100 Control Module. I designed this circuit. for my Great Nephew's Scooter.
1. The Brake is a normally closed switch that opens when you squeeze the Brake handle.
2. The throttle is two normally open switches that close when you turn the throttle.
3. The Kick Start circuit is described in the Diagram below.
4. The resistors values may need to be tweaked for best performance.
Google Link to what could be the Electrical Diagrams for E-100
1helpful
No power
Battery razor e 100 replace
Razor E100 electric scooters
I would like to have the instructions to the game of Mad Dash three minutes across America.
I have a ct-811b9 controller with my electric scooter and i un-hooked a connection and the controller almost littereally exploded and now the throttle does not work. i bought a new controller and now the...
  • Replacement 24V controller with 4 pin throttle connector
  • For Razor E100(Versions 10+), E125 (Versions 10+), E150 (version 1+) and E175 (version 18+) eSpark(version 41+), Trikke E2(versions 1+) electric scooters.
  • Replace Razor part #: W13111612164 Model No: ZK2400-DP-LD-ROHS7, ZK2400-DP-FS-ROHS7
  • The E100 series Razor scooter is a PUSH START scooter. You need to push the scooter, twist the throttle and then the motor will engage
  • 1-Year Warranty - Money-back satisfaction guarantee
7 connectors, 5 plastic connectors & 2 metal connectors
Re-assembling a E200 rear wheel
Click this link http://www.razor.com/support/pdf/manuals/current/e100-series-manual.pdf
Scroll down to chain and tire replacement. It has a full exploded diagram of the rear wheel
Top Razor Toys Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Kardoc
Are you a Razor Toy Expert? Answer questions, earn points and help others
