Please do the following : 1# Check main 15 amp circuit breaker (located on back of the machine) it may tripped, reset the circuit breaker. If breaker tripped again after reset, the circuit breaker need to be replace.
2# Verify line voltage is present at input of main power switch & output at switch turn ON. If line voltage is not present at power switch input, check connections between power switch and AC plug. If line voltage is present at power switch input, but not at output with power switch turned ON, replace power switch.
3# If all proceeding steps tested ok & problem still exist, you may nee to replace The main control module.
Hope this will help you, if so please vote for it.
