SOURCE: ptac fan keeps blowing
Try setting the fan control to "AUTO" this will cause it to cut out with the compressor.
SOURCE: water is filling up in drain pain
My suggestion is to NOT pull the plug on the drain that should be covered with a sign that says...do not remove plug. Water is supposed to be kept in the pan. The interior wheel then helps the water keep the condenser cool....Ron
SOURCE: Amana PTAC
Sounds like if this is a heat pump, maybe it tripped out on high pressure. Maybe just unplugging the system may reset the control boards. This maybe due to a dirty filter or dirty evaporator coil.
SOURCE: amana ptac shuts on and off constantly
your control board is shot and your ac can't tell the room is cold enough. 1-888-855-9987
SOURCE: Wiring Amana Heat pump to inside unit and 9520 robertshaw
colors can vary. you should be able to locate a wiring diagram inside the airhandler and out door unit. you will have to remove the panels. generally though Green is fan RED is power WHITE is reversing valve Blue is common YELLOW is the contactor (usually have to jump w and y terminals at robertshaw tstats. PLEASE DOUBLE CHECK AT SYSTEM DIAGRAMS!!
