Guest,
Are you still having problems recording live TV shows? You can try unplugging the receiver from the power outlet for 10 seconds and plug back in. This will make the receiver reboot and then acquire satellite signal. Once the acquisition is complete, a program guide download will take place. Allow the download and see if the receiver will allow you to record.
If it doesn't, then run a check switch test. Press your menu button to bring up the main menu. Press 6, 1, and 1 on the remote which will take you to the Point Dish screen. Upper right hand corner of TV screen is a button, "Check Switch". Maneuver to that button and select. You will now be at the "Installation Summary" screen. At the bottom of screen, select "Test" button. Allow the test to run. After completing, it will automatically take you back to installation summary screen. Check for any errors windows. Exit completely out of all menus till you are back to "Acquiring Satellite Signal". Allow program guide download after acquisition, then check if you can record.
I hope this helps.
Ray Calo
DISH Network
