Dymo LabelWriter 320 Thermal Printer Logo
Posted on Jul 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wont print Dymo 320 labelmaker won't print
Anonymous
Level 3:
Guru:
  • Master 480 Answers
  • Posted on Jul 27, 2010
Anonymous
Master
Level 3:
Guru:
Answers
480
Questions
Helped
122155
Points
1311
Hello
Check the usb cable.May be you will need to use a usb 2.0 one
thanks
Need instuctions for dymo label point 250
[email protected]. My manual is 12 pages long. Please put DYMO Manual as the subject and I will email it to you right away. Waiting for your response.
About Your New Labelmaker. With your new DYMO LabelPOINT™ 250
labelmaker, you can create a wide variety of high quality, self-adhesive labels. You can choose to
print your labels in many different sizes and styles. The labelmaker uses DYMO D1 tape cassettes in
widths of 6 mm (1/4"), 9 mm (3/8"), and 12 mm (1/2"). Tape cassettes are also available in a wide
range of colors.
Getting Started
Follow the instructions in this section to print your first label.
Connecting the Power
The labelmaker is powered by standard batteries or an AC power adapter. To save power, the
labelmaker will automatically turn off after two minutes of inactivity.
Inserting the Batteries
The labelmaker uses six 1,5V AA batteries.
To insert the batteries
1. Remove the battery compartment cover. See
Figure 2.
5helpful
Problem feeding 9m tape in Dymo 1895
I have one of these and there is a white sliding button on one of the broad sides of the labelmaker. It slides from 3/8 inch to 1/4 inch. It is located toward the top right. It's NOT the side with the letter wheel but the opposite side. If yours doesn't have t his button, it probably won't take two sizes of tape. (But I'd be surprised if it didn't have the button.) Hope you find it.
Dymo LabelManager 300
I would suggest reinstalling the driver.
First disconnect the label writer, then go to :
https://global.dymo.com/enUS/RNW/RNW.html?pg=std_adp.php&p_faqid=101
Scroll down and you will see your model number and download the drivers. Then run the installation again and it should prompt you to connect the label writer, which should fix the problem
If not also try reinstalling the "Label Software Application" listed on the same page as well.
2helpful
Spits out multiple blank labels and reports a printing error
I just fixed my coworker's Dymo, which had the same problem. I hope this helps: if you've ever fed it labels in the wrong direction (upside down), you may have jammed it and left a piece of a label glued to one or more of the sensors that let the labelmaker know it's finished printing a label.
1. Disconnect your labelmaker
2. Disconnect/remove any unused labels and set them aside.
3. Remove the face plate (with the DYMO LabelWriter 400 logo)
4. Lift the gray plastic lip (labels go under this) and make sure there are no pieces of paper/labels in there.
Once I removed a piece of an old label and put the LabelWriter back together it started working well again.
Does not cut through the tape
Here is what Dymo has to say about this issue:
https://global.dymo.com/enUS/RNW/RNW.html?pg=std_adp.php&p_faqid=68
Here is the text in case the link drops:
Question Why can't I cut the tape after printing a label?
trnsp.gif Answer Every time a label is cut, residue from the label's adhesive remains on the cutter blade. This is a normal occurrence when the LabelMaker is used frequently. It is important to regularly clean the cutter blade in the cassette compartment with either the special brush delivered together with the LabelMaker (located in tape compartment door) or a cotton tip swab and a soft solvent (e.g. alcohol).
If the solution above does not resolve the problem, check for tape path obstructions. If the problem persists, please contact DYMO Technical Support to obtain a Return Material Authorization (RMA) number. To obtain an RMA number, scroll to the top of this page and click on the Ask a Question tab. Make sure to include your full name, address, shipping, and contact information.
-Hope this helps
2helpful
Dymo 320 labelwriter downloadfor windows vista
Installing Dymo software on Vista can be a real nightmare if you fail installation at first time.
Call Dymo customer support, they will follow you step by step, ask you to download dymo uninstaller for your model, and tell you how to clean registry. They got used to this.
DYMO | Contact Us
Won't print
Here is the Dymo site for this issue:
https://global.dymo.com/enUS/RNW/RNW.html?pg=std_alp.php?p_li=&p_accessibility=0&p_page=1&p_cv=&p_pv=2.22&p_prods=21%2C22&p_cats=&p_hidden_prods=&prod_lvl1=21&prod_lvl2=22&p_search_text=&p_new_search=1&p_search_type=answers.search_nl
Type "light print" into the search box and the first result is the link you are looking for.
Here is the text of the link:
Poor Print Quality from Electronic Labelmaker trnsp.gif Question I have an electronic labelmaker that is printing poorly. The print on the label is either very light, incomplete, or striped. How can I resolve this?
trnsp.gif Answer Proceed with the solutions listed below if you have an electronic labelmaker. If you have a LabelWriter printer that is printing poorly, click here.
Solution 1:
Replace the existing batteries with a new/fresh set of alkaline batteries. The print head requires a significant amount of battery power to ensure proper printing on the label. Light print on the label may be an indication that the batteries need to be replaced.
Solution 2:
Replace the existing tape cassette with a new tape cassette. Light printing may be an indication of bad label stock.
Solution 3:
Using the special brush supplied with your labelmaker (located on the inside cover of the cassette compartment) or a cotton swab with a soft solvent (e.g. rubbing alcohol), carefully clean the transporter roller and print head. Dust, dirt, or glue may accumulate on the rubber transport roller or print head inside the cassette compartment and adversely affect print quality.
If the solutions listed above do not resolve the problem, please contact DYMO Technical Support to obtain a Return Material Authorization (RMA) Number.
Obtaining a Return Material Authorization (RMA) Number:
  1. Click the Ask a Question tab at the top of this FAQ.
  2. Fill out the email form completely and include the following information in the Problem Description field:
  • Full Name
  • Full Shipping Address (No PO boxes)
  • Phone Number
  • Date of Purchase
  • Model Name/Number
-hope this helps.
Top Dymo Office Equipment & Supplies Experts
Daniel Blask
Daniel Blask
Arnie Burke
Arnie Burke
ADMIN Andrew
ADMIN Andrew
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
