I have an LG WM2277HW washer. I got an OE error. I drained the washer, and ran it a few times. The drain pump was not working. I checked all hoses and the filter. Everything is clear. I got a new pump. It still doesn't work. I have an extra main circuit board. I swapped them out with the new pump in. Still doesn't work. I called LG and they wanted to set me up with a service call. I can't begin to tell you how disappointed I am with LG. I won't buy another product from them. Please help!
If you are getting this code it is because your washing machine has tried for at least ten minutes to drain the water out of the machine. The most likely cause of this problem is that you have a plugged pump filter or you have something stuck in the pump filter.Make sure that you unplug your washing machine.To clean out the pump filter you must empty the washing machine water. The best way to do this is to manually drain the water into a low bucket or basin. Then lay a towel down to catch to remaining small amount of water. Remove the pump filter, clean out any debris, and wash out the filter. Then plug your washer back in and restart the washing machine.Check that your machine is properly leveled. A washer that is too far out of level may not drain properly. Make sure that you are level front to back as well as side to side.This solution will solve your problem
Thank You !!
Well, I gave it one last try and it worked!! I took the whole pump assembly out, and checked both pumps (I only checked 1 the first time...dah!!). There it was - a penny stuck in the pump. It now works like a champ! Thaks for your help.
