RCA RS2650 Shelf System Logo
A
Anonymous Posted on Jul 03, 2010
My RS2650 randomly will freeze i have to unplug it I've tryed surge protecter and nothing
How do I fix Error message 5E on samsung refrigerator RS267TD which popped up after a power surge? I have already unplugged it for 5 minutes
I must admit I know nothing about modern computerised fridges, though I do know a bit about computers.
If you don't have your computerised appliances surge protected - modern tv and radio, hi-fi, fridge and so forth are in reality either computers or contain computers - one or more of them is likely to be damaged by a power surge or voltage spike.
Sometimes even with surge protection they can be damaged.
Bear in mind if damage has occurred it is possible the error message means little or nothing.
I suggest you read the instruction manual and then contact the manufacturer's customer service for advice and then perhaps ask a local repairer the same questions.
2answers
Offline
Did you have surge protection on this printer? If not, when the power went back on, the surge of current may have damaged it. Surge protection is very important on all devices with electronics in them! If it wasn't a very expensive printer to begin with, it won't be worth fixing whatever the cause. You can take it too a computer store and have it looked at, but they will charge for that, of course.
My HP G62-355DX goes to a white screen randomly and there's nothing I can do to fix it besides turning it off for a while. I've tried unplugging and plugging the video cable back in and I'
TRY HOOKING THE LAPTOP TO AN EXTERNAL MONITOR IF THE MMONITOR IS OK. THEN ITS THE CABLE CONNECTING THE KEYBOARD TO THE SCREEN. HOPE THIS HELPS. THS HAPPENED TO ME GOOD LUCK
Our electricity went out for a few minutes, and since then the TV will not turn on. The green light is flashing. We tried resetting it by pushing a pen point into the reset hole, but it does nothing. ...
Your power outage may have been caused by a nearby lightning strike, or any number of
1000 different reasons that cause power surges, brown-outs, voltage spikes, inductive loading,
and/or utility pole breaker trips and resets (this accounts for your power loss (a pole breaker trip),
followed by restoration of power (the pole breaker automatically reset) - even plain old high electrical demand causing an overload due to air conditioning demands caused by hot weather.
When the pole breaker reset, your TV caught a power surge.
Whenever a power outage occurs, quickly power off (or better, unplug) any/all computers, TVs,
etc. that are not protected by surge-protection.
As an electrician, when someone loses an item of electronics concommitant to an electrical
anomaly, its almost
always traceable to a nearby lightning strike (or the power company provided equivalent), accompanied by inadequate surge protection for
the VCR/TV/Computer/Stereo/uninsured valuable electronic item/XBOX 360/Nintendo Wii.
Surge protection can
be provided by the consumer at the power strip (a good one with builtin MOV protection and a
warranty costs $20, whereas a zero-protection 4-outlet or 6-outlet power strip will cost $4-$5).
Your electrician can provide whole-house surge protection where a whole-house MOV-based (metal oxide varistor) surge protector, or per-circuit protection can be installed with
a GFCI breaker (or better, an AFCI breaker) can be installed.
GFCI = ground fault circuit interruptor
AFCI = Arc fault circuit interruptor
Lightning protection is especially important in Florida, which is the "lightning capital of the world."
I've never found a good solution to lightning-fried electronics (random power supply components are destroyed and/or fuse blown), other than renters insurance or homeowners insurance.
Your only real hope for an economical fix is to look for a blown fuse, and replace it.
If desperate to attempt a fix on your own, you could try replacing the entire TV power supply as a module, but even this provides
no guarantee of a fix - lightning damage can extend beyond the power supply.
When traveling, I will always unplug everything before I leave (except the security system),
and also turn off the breakers to unneeded house circuits (which kills the wall switches that
control interior lighting - forcing a burglar to use their flashlight instead of interior lighting)
which is the least convenient lightning protection, but highly effective, and cheap (free).
1helpful
2answers
We had a thunderstorm with lightening in the area. The LG was plugged in at the time, but NOT turned on. after the storm, the tv will not turn on. the little green button turns from red to green...
As an electrician, when someone loses more than 1 item of electronics in a day, its almost
always traceable to a nearby lightning strike, accompanied by inadequate surge protection for
the VCR/TV/Computer/Stereo/uninsured valuable electronic item/XBOX 360. Surge protection can
be provided by the consumer at the power strip (a good one with builtin protection and a
Your electrician can provide whole-house protection, or per-circuit protection at
the breaker box, where a GFCI breaker (or better, an AFCI breaker) can be installed.
I've never found a good solution to lightning-fried electronics (random power supply components are destroyed), other than renters insurance or homeowners insurance.
The converter box may be replaced by DirecTV, you'd have to contact their customer
service at http://www.directv.com/DTVAPP/content/customerservice
If desperate, you could try replacing the entire TV power supply as a module, but even this provides
1helpful
Both of my tv's died yesterday. My apex wont turn on anymore an the panasonic has no picture. Whats wrong.
As an electrician, when someone loses more then 1 item of electronics in 1 day, its almost
always traceable to a nearby lightning strike, accompanied by a lack of surge protection for
If desperate, you could try replacing the entire power supply as a module, but even this provides
1helpful
After a bad lightening storm, our Intermatic HB88RC timer is stuck on zeros and won't budge for setting the clock or programs. Is there a way to reset it and start over? We've unplugged it for a...
Open following link to identify timer, download manual and see replacement product for discontinued HB88
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#hb88
Electronic timers are susceptible to power surge, even nearby surge that gets picked up by household wires or internal timer parts. All wires carry current when exposed to nearby current. Same principle when cell-phone recharge transformer converts 120V to lower volts-amps without wires directly connected.
HB88 timer is reset by removing/replacing AA battery.
If reset does not restore functionality, then timer has gone bad.
Whole house surge protector can protect circuit breakers and electronics that are not connected to typical power-strip surge protector. For example HVAC unit and electronic water heater controls are not protected from surge. Household items that are connected to co-ax cable also need separate protection.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#surge
We had a really bad storm yesterday with a lot of lightning. our power flickerd on and off a couple times but all of our electronics are plugged into surge protectors. everything in our house is working...
Few mins will not resetting tv and recovering power supply board from it protection modes that quick.Tries tv unplug,replug it back like about an hour later for tv resetting it back to the factory setting.The tv should get out it protections modes and might work again.If tv still have the same problems,than enough high currents got in the tv and kill ur tv power supply board.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
4helpful
2answers
Reset my soundbar
Amp is probable going into protection mode. Disconnected all speaker and av wires (only power) and check if it switches on. Try to plugged it in also at another wallsocket. Presume PSU damaged by surge
Top RCA Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
