Dryers Logo
Posted on Apr 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Our maytag ensignia dryer stop working, the light comes on when we open the dryer door, but when we try to put it on a drying cycle it doesn't work. It doesn't even try to start it seems like it is totally dead.
  • Anonymous Apr 25, 2008
    Had a storm come through with several power outages. Now the dryer will run for approx 5 seconds then shut off. when it shuts off all the LED's around the dial flash one time, a second or so later, they all flash again and that's it. Is this a trouble code of some kind? Thanks, Kevin model # MDE4658AYW serial # 10458827GV
  • Anonymous Mar 26, 2009
    Purchased 2006, All lights work on the dryer however it will not turn on. Model # MDE4658AYW. Appears you have to take the entire dryer apart just to check the motor ?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 18, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1150
Points
I HAVE A MAYTAG ENSIGNIA DRYER 2 YEARS OLD AND IT WONT START UP UNTIL THE BARREL IS TURNED BY HAND TO A CERTAIN POSITION ? CANT FIGURE IT OUT.
Anonymous
Level 3:
Genius:
  • Master 1,073 Answers
  • Posted on Apr 23, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1073
Questions
0
Helped
392030
Points
2842
What is the model number
The dryer just stopped working. No light inside
Hope this dosent seem to simple ,but have you tried changing the fuse in plug?
Maytag Neptune dryer MDE 6700AZW Stops working
try a simple test before you try to gain axcess to the console parts unplug the power cord 1 min plug back in and put in time dry not auto or it will time out quickly without wet cloths see how it does and if this not solve you problem repost with model #
3helpful
3answers
Dryer doesn't work.
Dry will not start, light is off. Power is on and working fine to dryer - is there a reset button?
Performa oversized Capacity Plus Model #PYE3360AYW .
I have a maytag ensignia, the dryer does not work on sensor dry
im not just sure about what your saying.but if the door latch is broken on the door or in the body of the dryer you need a door latch kit
Jan 01, 2009 • Dryers
Maytag Ensignia Model MDE6657BYW stopped...
yep there is and it is on the right side of the heater housing, it is connected by 2 white wires, you have to remove the heating element toget at it part is a la-1053
1helpful
2answers
Maytag Electric Dryer Stopped Working
Check spring tab behind door switch-if it's bent/out of adjustment, circuit will act like door is always open.
To confirm this, open door, set dryer to active setting, and hold in door switch; if it comes on, then it's either the spring tab, or the switch is malfunctioning
Mar 30, 2008 • Dryers
Top Dryers Experts
john h
