Washer stopped and flashed LF and now won't start. Any ideas what is wrong?
Hi
Error code LF means long fill. This means that analog water level pressure sensor signal is out of range or the water pressure is very low. The analog pressure sensor is a component on the machine control board. The normal water pressure is 100-200 PSI, when the pressure below 40 PSI then this error occurs. Verify the pressure at all other water sources in the house and check if its low at all places, if its low then contact the water company. Also check the inlet water hoses if they are kinked. Inspect the inlet water valve as well.
If you find no problems with the air hose or water pressure and its connections, then the machine control board would need to be replaced.
Please post back for any further assistance.
Daniel
Hi
LF means Long Fill, this error flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change. Check whether water supply is connected and turned on. Make sure the hose is not blocked and hose screen is clear. If so make sure pressure hose connection to machine/motor control is fine. Also check the continuity of water inlet valve, use a multimeter to check the continuity. Hope this helps... Please post back if you need more information.
Daniel
