Televison & Video Logo
Posted on Apr 23, 2008
Mitsubishi (2001 ?) 60 inch projection TV Model VS-60609. DVDs and video games work perfectly but NO tv reception- we have Comcast. I've plugged cable into every possible hole on the TV- no luck. THX!
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 25, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
172
Points
My mitsubishi 2001 tv model 60609 plays sometimes for a couple of minutes and then turns off; but you can still hear the volume and if you try to turn it back on it will turn right back off.
please help me!
My tv will not turn on
Does the set if model listed here is correct come on with the green power light for a few seconds and then that goes off?
I have a vs-60609 60"
Sounds like a Picture in Picture screen popping up, but if you do not have a signal from another tuner, it will be blank.
Try hitting the PIP button on your remote to see if it turns it off and on.
Plus go into the tv menu and find the PIP settings.
Mithsubishi Projestion TV MDL VS-60609-Picture bow
Sounds like bad convergence chip. I think you can get a kit to repair it at www.tvrepairkits.com
You need to be good with a soldering iron if you plan on doing this yourself.
Mitsubishi VS-60609 60 in. no pix /has sound
My Mitsubishi TV model VS 60609 is showing double vision on the screen.
Cleaning lenses/lamps on mitsubishi VS-60805
A can of compressed air might do the trick. If dirt is stuch, I'd suggest useing the same chemicals/cloths/etc you would use for cleaning camera lenses. Check at your local photo store.
Just make sure the lenses aren't hot when you apply cold and/or flamable chemicals.
2helpful
2answers
Mitsubishi VS 60609 60 inch
Hi, I need a Diagram for a Mitsubishi VS-60609 my E-mail: [email protected] Thanks!!!
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
