follow the below instructions:
Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
Press a series of four buttons in quick succession. Press "Heated Dry,"
"Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore
dishwasher to run a short diagnostic test
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its
diagnostic test. This should reset your dishwasher control panel and
stop the "Clean" light from blinking repeatedly.
Good luck.
Press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
You can also pres "normal wash" and "heated dry" buttons back and forth and it will reset the dishwasher and work normal again
