D-Link Dlink DI-514 Air Wireless 2.4 GHz Router (A0177337) Logo
Posted on Jul 26, 2010
Should the status light be blinking?
I can't get wireless internet. The router does not seem to be working. Should the status light be blinking?
D1-524 D-link wireless router
The status light and WLAN are blinking.
Anonymous
Level 1:
New Friend:
  • Contributor 38 Answers
  • Posted on Jul 26, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
38
Questions
0
Helped
12603
Points
98
You should call the wireless manager.
good luck.
  • eagerl Oct 25, 2010
    a pathetic answer of no value whatsoever
Hi , my d- link wireless router just stopped working yesterday. I can't seem to get it to connect to the internet and none of the laptops are getting wireless internet. There are 2 lights that are blinking...
Verify the connections are correct, The WAN port should be connected to the Cable/DSL modem. Then do a hard reset (hold in the reset button for 30 secs). If this doesn't work, try another router to isolate the problem.
Airnet router with blinking status light
first, check and make sure you have the correct power adapter for the router. second, reset the router my holding the reset button for 30 seconds
Dl-524 status blinking, cant connect to internet
- Updating the firmware of your router will do to fix the issue.
D-Link Airplus di-524 wireless problem
Hello.
The status light is blinking in all dlink models, so that is normal.
The wireless radio issues have 3 possible solutions.
1. This model has a antenna that screws in the bnc socket behind it see if it's well screwed, or substitute it by another if 2 and 3 don't fix it.
2. On the advaced settings of the wireless configuration you have the ratio of radio broadcast from 25% to 100% check to see if it's on 100%, change channel to 11 if neer and 6 if far, make sure you have SSID broadcast enabled.
3. This models allow you to restart the AP unit and the router unit idependently, so it's always good pratice to restart your AP in the tools and system comands menu.
Hope that helps.
Ineed to know what blue light tells me that my router is working?
Hi jackmyrtue,
Here's what the lights on the front indicate:
A. Wireless Security
  • OFF Wireless security is off
  • Solid Blue Wireless security is on
B. Wireless-Computer Status
  • OFF Wireless computer is not present
  • Solid Blue Wireless computer is connected to the Router
  • Blinking Amber Problem with wireless computer onnecting properly to the Router
C. Wired-Computer Status
  • OFF Wired computer is not present
  • Solid Blue Wired computer is connected to the Router
  • Blinking Amber Problem with wired computer connecting properly to the Router
D. Router/Power Status
  • When you apply power to the Router or restart it, a short period of time elapses while the Router boots up. During this time, the "router" icon blinks.
  • When the Router has completely booted up, the "router" icon becomes a solid light, indicating the Router is ready for use.
  • OFF Router is off
  • Blinking Blue Router is booting up
  • Solid Blue Router is on and ready
E. Modem Status
  • This icon lights in blue to indicate that your modem is connected properly to the Router.
  • It turns amber when problem is detected.
  • OFF Router is NOT connected to modem
  • Solid Blue Router is connected to modem and functioning properly
  • Blinking Amber Problem with modem
F. Internet Status
This unique icon shows you when the Router is connected to the
  • Internet. When the light is off, the Router is NOT connected to the Internet.
  • When the light is blinking amber, the Router is attempting to connect to the Internet.
  • When the light is solid blue, the Router is connected to the Internet.
When using the "Disconnect after x minutes" feature, this icon becomes extremely useful in monitoring
the status of your Router’s connection.
  • OFF Router is NOT connected to the Internet
  • Blinking Amber Router is attempting to connect to the Internet
  • Solid Blue Router is connected to the Internet
I hope this helps figure out your PS3 issue.
Thanks and don't forget to leave a rating.
Mark
1helpful
Router not working, help please!
You may may need to configure your D-Link to use your type of internet! Try following the Quick Install Guide which can be found here: ftp://ftp.dlink.com/Gateway/di524/Manual/DI-524_manual_06292005.zip The WLAN light doesn't come on probably because you have the wireless disabled, which can be re-enabled once in the configuration for the wireless(in the document mentioned above) If you are having any difficulty following the guide or have folloed the guid and still can't connect, please get back to me regards, babb
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
