Apple iPod nano Logo
Posted on Jul 25, 2010
My ipod nano stop working and when I plug to computer
My ipod nano stop working and when I plug to charge it will do any thing
Anonymous
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Jul 25, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
5326
Points
22
Always connect to the same computer. If the I pod is recognised - updat the software. If not - reset it (http://support.apple.com/kb/ht1320), which is different depending from the model. It will re-install the operating system and your files will all be deleted - a First a working operating system will be instlled - then it will restore all your files :-)
I have an ipod model a1199. i was wondering if you can use a newer ipod touch charger for it? and if not what kind of charger does it use?
Charge an iPod Nano Without a Charger
If you've misplaced or broken the charger that came with your iPod Nano, you might think you need to purchase a new one in order to continue using your Mp3 player.
However, there is a way that you can continue enjoying your iPod without having to purchase a new charger.
As long as you have a USB cord and a computer, you can charge your iPod without having the charger.
Locate the USB cord that came with your iPod Nano package.
It is the same cord that you use in order to sync or transfer music.
Plug the small end into your iPod Nano.
Plug the other, larger end into your computer's USB port.
Choose "Do Nothing" when your computer presents the dialogue box to let you choose what to do with the hardware or USB connection.
Leave your Nano plugged into your computer for at least 4 hours to charge.
Unplug your iPod Nano when charging is complete.
Charge an iPod Without the Charger
Many iPod owners purchase a charging unit that plugs into a standard wall outlet to recharge the iPod's battery.
However, the iPod wall charger is not included with new purchases, so consumers must either purchase a separate charger or find a way to charge their iPod using other means.
Here's a simple method to charge your iPod using your computer.
Plug the iPod USB cable into the bottom of your iPod.
Plug the other end of the iPod USB cable into a free USB port on your Mac or PC computer.
Open the iTunes program by clicking on the icon in the Dock on a Mac or using the Start menu on a PC.
Click on the name of your iPod under the "Devices" heading in the main iTunes window.
Click on the "Sync" button to synchronize your iPod with your computer data.
While the iPod is syncing, the power from the USB port on your computer will charge your iPod's battery.
Unplug your iPod from the computer once the battery is fully charged.
http://www.bing.com/images/search?q=images+of+apple+ipod+usb+chargers+&qpvt=images+of+apple+ipod+usb+chargers+&FORM=IGRE - view=detail&id=8DEA58C0DAF392E29FCB03D9C
This one should be ok.
I have apple iPod 2Gb. It doesn't start. it's display only busy icon. I think's it's frozzen how to sove this problem
How to Fix a Frozen IPod Nano
iPod Nanos will sometimes freeze up, sticking on one screen or not even turning on at all. If your nano is locking up, there are a few things you can try to get it working again.
1. Turn off the hold button. First of all, make sure that that wasn't the problem--don't worry, we've all done dumber stuff.
2. Cold boot. Assuming that wasn't the problem, flick the hold button on and off a few times, and then make sure it's off. Hold down the Menu button and the middle button button for about 15 seconds; this should reset the iPod nano, which may fix the issue. Make sure that the iPod nano is fully charged before attempting this.
3. Recharge. If that didn't work at all, try plugging the iPod nano into the USB port of a computer, using the adapter that came with it. Be sure to plug directly into the computer, and not through a USB hub. The USB needs to provide adequate power for the iPod nano to function, and it may be unable to do so through a hub. The iPod nano should be recognized by the computer; once it is, you simply need to safely disconnect it in iTunes, and it should be functional. If it doesn't show up on the computer at all, give it about 20 minutes, leaving the iPod nano connected to the computer, as the nano may be under-charged, which requires a few minutes to re-charge. If it's still not working, try plugging the iPod nano into a different computer.
4. Try again. If the Menu + Middle Button fix seemed to work, but just cycled the nano back to one of its starting screens (including the "do not disconnect" or the "loading Apple logo" screen), try that fix again. If it still doesn't work, try to charge it for a while, and then try it once more.
1helpful
2answers
New Ipod Nano 4th Gen 16GB has went blank and will not turn on
HI there,
worst case scenario is that a circuit has broken inside. But your ipod will be under warrenty for a year from purchase.
Otherwise, leave the ipod to charge for a long time. Just leave it connected directly to the computer USB port despite not having any change in appearance. Also, don't connect it via a usb hub or through your keyboard. You will need to plug it into your computer directly.
You can also try entering DFU mode. Here is a great step by step guide to do that. http://iphonefreakz.com/beginners-guide/howto-dfu-mode/
Then restore the ipod and update the firmware. Make sure you have the latest version of itunes installed. By checking through software update.
I hope this helps,
Nathan.
Apple iPod Nano 3rd gen won't turn on nor charge
If you guys still have this issue, I would strongly recommend going to the following web site:
http://fixyouripod.weebly.com/
There is an instructional video on your exact issue. :) good luck. I hope it's not too late for your iPod's
1helpful
When I charge my iPod Nano it charges fine but instead of turning off or ... it will turn off but in about 2 seconds it goes to the "Charged"
You need a new battery for your iPod. you can view a free instructional video on battery replacement at the first web address posted below. the second one is a cheap site I found for purchasing iPod parts.
http://www.ifixit.com/
Problem with ihome and ipod nano.
yes, unfortunately the ihome iH9 is not compatible with previous models of the ipod nano.
if you want a similar device, there are many other docking stations for the ipod that are ip0 that ARE compatible with the ipod nano 2G
iH85B is another ihome dock which is compatible with all ipods after the ipod mini (including the ipod nano 2G)
http://www.ihomeaudio.com/products.asp?product_id=10186
Ipod nano touble
Did you try charging it with the USB cord or do you have an adapter that plugs into the wall? If you tried with the USB cord, how long did you let it charge?Did you plug cord directly into computer or do you have external USB hub?Many times the hubs will not have sufficient power to charge.Was your computer"go to sleep"after a while.The ipod will only charge while the computer is awake.
There are a variety of things that could be wrong. If the Ipod sat for a long time the battery could be completely discharged. I've not had this problem on the Nano, but on an old Ipod Mini my sister has. I've noticed that sometimes I need to plug it in with a wall adapter to get the battery charged enough to start up quickly. If the battery is completely discharged,it can take 30 minutes or longer to see any life from the ipod. I would let it charge for few hours if you can then try the reset.
Forgive me for asking this next question...lots of times I ask these basic question and people get mad, but the key lock is off, right? On my Nano there's a small slider switch on the top. In one position the controls are all locked. Please verify that you've got it set to the right position. Mine is locked when I can see the red dot.
Assuming the battery is not totally shot and the key lock is off, it's also possible that it's just "locked up". To reset the Nano press and hold both Menu and Select (center button) for about 5 or 10 seconds. If the Ipod is alive this will reset it.
From your post, I'm not sure if you mean the Ipod was sitting for a long time without being used. If that's the case and it used to work, and it has not gotten wet or anything, then the most likely problem is a bad battery. There are services on the web you can find who will replace the battery for a fee. If, on the other hand, it just suddenly stopped working and the reset does not help you may have a more serious problem.If problem exists you better replaced the battery. Unfortunately there's no way to tell.
Hope this may help you;
Regards,
VOTIT
My itunes won't detect my ipod nano 4gb
well sometimes what people do is that they plug in the usb cable before the computer is on and it wont recognize the ipod. You have to turn off the computer and wait till it is on and then plug it in.
1helpful
My ipod nano wont do anything
Try this
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
if noting helps, see the bottom of the page for service information.
Ipod nano 1st gen sync/charge problem
Try these options i got them from apple when my ipod dident work trying a new port and reinstalling itunes worked for me 1)Reset your iPod. 2)Retry with a different USB or FireWire port. 3)Restart your computer and make sure you have the latest software updates installed. 4)Remove iTunes software and then reinstall iTunes software from latest versions on the web. last resort 5)Restore your iPod. See ?Updating and Restoring iPod Software? in the user's guide.
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
