Question about NorStar M7310 Corded Phone
Initialising Mailbox We have a new Norstar M7310 we are trying to set up the mailbox, however when we go to initialise the mailbox by pressing 'feature 9 8 1' it says 'inactive feature' what does this mean? and how can we fix it?
  • 326 Answers
To Log Into System Administration:
1. Enter Feature 983
2. The display will show "LOG", enter your login password
a. If your company extensions are 2 digits long enter "120000"
b. If your company extensions are 3 digits long enter "1020000"
c. If your company extensions are 4 digits long enter "10020000"
3. Press the softkey under "OK"
To Create a New Mailbox:
1. Log into system administration
2. Select the softkey under "MBOX"
3. Select the softkey under "ADD"
4. Enter the mailbox number (extension. you want to add
5. Mailbox type: Subscriber and then select "OK"
6. Extension: Usually the same as the mailbox number
7. Service Class: Enter 1
8. Name: Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma, and then enter the first name. When spelling the name, press # to move to the next character
9. Directory: Y (Yes.
10. Message Waiting: Y (Yes.
11. Out dial: Pool, enter 1 and then OK
12. Accept: 1, select OK
To Delete a Mailbox:
1. Log into the system administration
3. Select the softkey under "DEL"
4. Enter the mailbox number (extension. you want to delete
5. Select the softkey under "Delete"
To Reset a Mailbox Password:
3. Select the softkey under "Chng"
4. Enter the mailbox number you want to reset the password for
5. The display shows "Reset Password"
6. Select the softkey under "RESET"
7. Press the release key
*The new password will be "0000", the system will ask the user to change this the first time they log into their mailbox using this password.
To Change the Name on a Mailbox:
4. Enter the mailbox number (extension. you want to change the name on
6. Select the softkey under "Next", keep hitting "Next" until the display shows the name
7. Select the softkey under "Chng" to enter a new name
8. Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma and then enter the first name. When spelling the name, press "#" to move to the next character
9. Select the softkey under "Next" to save the change
10. Hit the release button
To Change the "Recorded" Name for the Company Directory:
1. Have the Voicemail User log into their mailbox, after putting in their password, press the button under "Admin" (or press the number 8 key., and then press the number 1 key.
2. You will hear the old recorded name and then the system will "beep", prompting you to record a new name (name only here, not greeting..
3. Press "Ok" in the window when you are done recording and then "Ok" again to accept the recording
Posted on May 02, 2008
SOURCE:
I work at a small company and recently they have set me up a voice mailbox on a norstar m7310 Phone and Star Talk mini. The mailbox works fine but the store manager is unable to configure my phone to...
In the mailbox setup, there's a prompt called EXT .. make sure your extension number is there. There's another prompt called MSG WAIT (or something like that) which needs to be set to YES or Y. The person that setup the mailbox should be able to get to these settings.
May 13, 2011 | NorStar Meridian M7310 Phone
We have a norstar m7310 and the mailbox is locked due to too many failed password attempts. I did log into the System administration and reset the password to that mailbox and it is still locked. How do I...
When you reset the password, it goes back to the default of "0000". When you try to log into that mailbox the next time, it will prompt you to change the password. Hope this helps!
Oct 21, 2009 | NorStar M7310 Corded Phone
I have the same problem: mailbox locked
How to Change a Mailbox Password (Administrator Only) 1. To access the voice mail system press "Feature".
2. Press "983".
3. When you see "Log:" enter "120000" for 2 digit extension numbers, enter "1020000" for 3 digit extension numbers.
4. Press "OK".
5. Press "MBOX".
6. Press "CHNG".
7. Enter the mailbox number (same as extension number) you wish to reset.
8. Press "Reset" softkey.
9. Press "Rls" to exit (orange button to the right of the number buttons).
The Default password is "0000".
Sep 11, 2009 | NorStar M7310 Corded Phone
I locked myself out of my voicemail for Norstar M7310!
Feature 983 is system admin
2. Select the softkey under “MBOX”
3. Select the softkey under “Chng”
5. The display shows “Reset Password”
6. Select the softkey under “RESET”
*The new password will be “0000′, the system will ask the user to change
Aug 06, 2009 | NorStar M7310 Corded Phone
I am getting "invalid mailbox" when trying to reset password.
Also, are you sure that this mailbox was ever created? Perhaps it was deleted? What happens if you do:
Feature 983
Enter pw
MBOX
ADD
Enter EXT
Apr 23, 2009 | NorStar Meridian M7310 Phone
Mailbox locked how to unlock it
First you will have to find out the extension number that is giving you issues.
2. Press "983".
4. Press "OK".
5. Press "MBOX".
6. Press "CHNG".
7. Enter the mailbox number you wish to reset.
8. Press "Reset".
Apr 20, 2009 | NorStar M7310 Phone
Information mailbox
Solution
Feature 983 - enter password 102xxxx
Mailbox
Change
Enter mailbox number
Password hit next
Extension hit next
service class change to 1 for regular mailbox, 7 is for information mailbox
Sep 11, 2008 | NorStar M7310 Phone
Norstar ICS 4.0 password
How to Change a Mailbox Password 1. To access the voice mail system press "Feature".
2. Press "983".
4. Press "OK".
5. Press "MBOX".
6. Press "CHNG".
8. Press "Reset".
Jun 20, 2008 | NorStar Meridian M7310 Phone
NorStar M7310 Corded Phone Logo
572 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
pbxinc
martin hogg
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
