TV will not turn on. Lamp indicator light is flashing yellow. Status indicator is flashing amber.
This is fairly typical of a main power supply failure.
There are (at least) two supplies in your set; one of them is on all the time so the set can respond to remote signals.
The other (and the possible third) is turned on when the set is used.
If you feel adventurous, comment back to this thread and I will provide some guidance if you no longer have any warranty coverage.
Thank you, the warranty expired two weeks prior to the storm if it going to be an expensive fix I will downsize to a 65" with a warranty
Very often such failures are caused by chemical (electrolytic) capacitors andthey are made to break open or bulge if pressure builds internally. This makes them fairly easy to spot because the tops of the cylindrical package has triangular linear dents that are flat when OK and obviously bulging if failing as they mostly do.
Why the interruption Fixya?
Most sets with this weakness are fixed by the replacement of several of these parts and an honest tech will not charge a ton of money to do this and the parts are cheap- that's why they fail.
LED Indications
The front panel Status LED provides an indication of
the set's operation and the possible cause of a malfunction.
If an abnormal condition is indicated, perform the
Self Diagnostics procedure.
Self Diagnostics
To activate, press the front panel <ACTIVITY> &<CH
??> buttons at the same time and hold for 5 seconds.
The STATUS LED will then flash denoting a two digit
code.
• The number of flashes indicates the value of the
MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2
second.
• The LED then flashes indicating the value of the
(ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED
will flash two times, pause, and then flash three
times.
Table 2-2: LED Indications
Error Codes, descriiptions and the most likely cause of
the error are listed in Table 2-3.
Note: The TV must be in "Shut Down." The LED
will probably be indicating an abnormal
condition. If the TV is switched Off, AC is
removed, or a System Reset is performed, the
code automatically resets to "12" No Error.
See the Error Code Log to retrieve a history of
errors.
Note: Use the front panel buttons, not the remote
control.
Note: If there is no response, the front panel may be
locked by a V-Chip setting. To unlock, press
and hold <ACTIVITY> on the front panel for
8 seconds.
LED Indication Condition
Off Off (standby)
Green Power On
Slow Blink Green Power Off with Timer Set
Fast Blink Green (80 seconds) > Off Power Off (Cooling fan still working, 80 sec)
Red Lamp Failure
Yellow TV Too Hot
Slow Blink Red TV May Require Service
Slow Blink Yellow Lamp Door Open or No Lamp Installed
NORMAL INDICATIONS
ABNORMAL INDICATIONS (For details perform Self Diagnostics Procedure.)
