My Maytag dehumidifier will not extract water. I cleaned the filter and no matter where I set it it will not work. It is only 1 year old.
Model is m7dh45b2a
Unit does not deposit moisture in tank, but moisture does drop on floor under unit. Have unplugged unit for short time and replugged unit to electricity and installed hose to unit for external moisture removalUnit does not deposit moisture in tank, but moisture does drop on floor under unit. Have unplugged unit for short time and replugged unit to electricity and installed hose to unit for external moisture removal
No water extracted. Filter is still as clean as new. Removed back and front and found that black wire that attaches to one of the copper coils is rusted at the attachment point. This unit was only used for a few months. Can this be repaired or is it not worth it? Thank you. Whit Raymond 609-306-4091
You can't post conmments that contain an email address.
There are 5 basic, but solvable reasons for what you described. Please pay particular attention to numbers 1 & 2.. 1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have an analog unit set the humidity extraction knob on Maximum.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the Unit, before removing to inspect & clean it, if necessary. If washed, allow filter to completely dry before reinstalling. DO NOT operate the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures (Unless, you have a Low Temp Unit). This applies mainly to where the air
temperature at floor level is colder than at shoulder level in basement applications. Raising the unit up off the floor, onto a sturdy table, counter top, etc, that can handle the weight of the unit, plus a full tank of water, will usually resolve this problem.
If
none of the above solves the problem, it may be a case of the
compressor needs to be recharged with refrigerant gas or that the humid-i-stat has failed. These things usually occur in units that are
5 years old or older. It's rare in a unit younger than that. But, it
can happen.
I hope this helps you to troubleshoot and solve the problem. Thanks for choosing FixYa.
There are 5 basic, but solvable reasons for what you described. Please pay particular attention to numbers 1 & 2. 1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have an analog unit set the humidity extraction knob on Maximum.
If
compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are
can happen.
I hope this helps you ro troubleshoot & solve the problem. Thanks fr choosing FixYa.
Gayle, your unit has some age on it, but it may still be salvageable .
There are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2.. 1. The humidity extraction level is set to HIGH. Lower it to 32-35%. Or set to Maximum if yours is a manually controlled unit.
If
5 years old or older. As far as repairs are concerned: The unit is 14 - 16 years old and the cost to repair, may be as much (or close to it) as purchasing a new unit. If you decide to purchase a new unit, be sure it's a "Low Temperature" model, as yours is being used primarily in a basement application.
I hope I have helped you and thanks for choosing FixYa.
According to your Owner's Manual. once the humidity extraction level is set at 35%, you should push the minus (-) key one more time to turn the unit ON. It will now run continuously no matter what the humidity level is until the bucket is full.
Todd, there are 5 basic, yet solvable reason for what you described. Please pay particular attention to numbers 1 & 2. 1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have a manually controlled model, set the humidity extraction level on Maximum.
temperature at floor level is colder than at shoulder level in basement applications . Raising the unit up off the floor, onto a sturdy table, counter top, etc, that can handle the weight of the unit, plus a full tank of water, will usually resolve this problem.
If
compressor needs to be recharged with refrigerant gas or that the humidity connenser sensor has failed. These things usually occur in units that are
There are 5 basic, yet solvable reason for what you described. Please pay particular attention to numbers 1 & 2. 1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have a manually controlled model, set the humidity extraction level on Maximum.
If
can happen.
There are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2. 1. The humidity extraction level is set to HIGH. Lower it to 32-35%. If you have a Manual Control Unit, set the humidity extraction knob to Maximum.
temperature at floor level is colder than at shoulder level, in basement applications. Raising the unit up off the floor, onto a sturdy table, counter top, etc, that can handle the weight of the unit, plus a full tank of water, will usually resolve this problem.
If
can happen.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Susan,there are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2.. 1. The humidity extraction level is set to HIGH. Lower it to 32-35% If you have a manually controlled model, set the humidity extraction knob to Maximum..
If
can happen.
I hope this helps you to troubleshoot & solve the problem.
Martin, you may not need to have it repaired if you check and troubleshoot, these 5 basic things that can cause this problem. All are solvable. Please take note of # 1.
2. Air intake filter is dirty or clogged. Turn unit OFF, remove and clean it, if necessary. If washed, allow filter to completely dry before reinstalling. DO NOT operate the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air space around the entire unit.
5. Ambient air temperature at floor level is between 40 - 60 degrees F. Dehumidifiersdo not work well between those temperatures (Unless, you have a Low Temp Unit). This applies mainly to basement applications, where the air temperature at floor level is colder than at shoulder level. Raising the unit up off the floor, onto a sturdy table, counter top, etc, that can handle the weight of the unit, plus a full tank of water, will usually resolve this problem.
If
humidity sensor has failed. These things usually occur in units that are
can happen.
Thank you.
Whit Raymond
609-306-4091
