Probably a "O" ring as the seal
if the pump is doing what it is supposed to be doing and everything is normal. I would not stress about air under the cover as water contains air in suspension ( how fish get their oxygen to live) and from the turbulent action of the pump impeller , some of that air will be released and collected at the highest point of the flow line
SOURCE: Jacuzzi - GFCI keep tripping prventing Jacuzzi
i have the same model after unplugging everything one by one i got the breaker to stay on with the transformer unplugged. ordered new transformer installed works great!!
SOURCE: I have a Jacuzzi pool filter and it leaks like a
when you replace the oring make sure to get some o ring lube and liberally apply it it helps a lot to keep it from kinking or bunching up when being tightened
SOURCE: I have an above ground
I think you have a air leak. A 1.5 hp motor is very strong and should vacuum well. Be careful to not over tighten the top of your pump housing.
Is your impeller in good shape? It may be worth your while to remove the pump motor from the pump. While you have it apart, replace all the seals (there is a kit for this). Inspect the impeller and all parts of the housing - any junk inside? Remove it. After you complete the rebuild, reinstall the motor, fill the pump housing with water, secure the top and start the pump.
Let me know what happens ...
thanks for your interest in FixYa.com
