Question about Buck Scrubbing Bubbles& Automatic Shower Cleaner - 2 Pack
Scrubbing bubbles sprayer does not spray
My scrubbing bubbles sprayer produces foam, but does not actually spray it. i replaced the head onto a new bottle, but it didn't help. the batteries seem to be good.
3 Suggested Answers
SOURCE:
SOURCE: Scrubbing Bubbles Automatic Shower Cleaner quit working
I just experienced the same problem for the third time. Call J&J Customer Care 1-800-558-5252. Select option 3.
Explain your problem and they will send you a coupon for a new Scrubbing Bubbles Starter Kit with a full bottle of solution in 7 to 10 business days. I would not waste my time to take the old apart, just call and get a NEW ONE.
Jim Jones
Jimjones0348@yahoo.com
Posted on Dec 09, 2009
I used a Torx bit and took the first one apart. I got it running for about one week.
I took a chance and bought another one, thinking the first might have just been faulty. Bad decision, the new one quit after 3 weeks. I put new batteries in and it beeped 3 times and never started.
Bad design.
Posted on May 15, 2011
Ring doesnt keep air
Put some Ivory dish soap, about a tablespoon, in a quart bottle with a sprayer, and fill the ring with air.
Then start spraying the soap solution all over that ring. When you see "Bubbles" appearing, that is where the leak is. Patch it. Fill with air & repeat. If no more bubbles, you have fixed it.
Apr 06, 2014 | Intex Easy Set Pool 15x36
Roundup battery propelled sprayer not working
Fix for electric spray wand not working that worked for me. Yes my wand would only spit out some foam, and nothing appeared to be clogged. The wand would spray just fine when I placed the siphon tube into a bucket of water.
Apparently what was happening was that the wand pump was creating a partial vacuum in the air tight canister, causing the electric pump to stop pumping. After all the battery pump is not all that powerful, just got a little foam. So I unscrewed the cap about one turn allowing replacement air into the canister and the wand started working.
Apr 06, 2013 | Garden
How do you use fluorescent gas leak detector fluid? I got a small tube with the gas line installation kit for my new range.
Adjust desired spray pattern. Spray to coat the suspected leak. Look for bubbles or foam. Microscopic leaks are indicated by foam, larger leaks produce larger bubbles.
Feb 02, 2013 | Nu Calgon 4184-53 Gas Leak Detector,...
Kohler a112.18.1 diverter will not spray
Generally the sprayer trigger assembly will unscrew from the hose. You can then point the hose toward the sink and turn on the
water. It should flow freely through the hose when either the hot or cold is on. Generally there is a aerator on the spray head. You can access it by unscrewing the tip of the sprayer assembly and clean out any mineral deposits. There may also be an inline type filter in the handle where it screws onto the hose that can be removed and cleaned. If this doesn't help I would guess the on-off triggering assembly is broken and you would have to replace the sprayer head.Hope this helps.
Jan 05, 2013 | Kohler Plumbing
Spraying kitchen cabinet doors 40 degree weather airless graco sprayer enamel water base paint at first finish is great then bubbles start to form
first problem is the waterbase paints ( ****) the other is how did you mix your paint , you cam trap air in the paint if you padle or stired it without a shaker mixer air will gas out of the paint, tofix this use a foam brush to flaten air bubbles
Jan 23, 2011 | Air Tools & Compressors
Jim Jones
Oct 14, 2009 | Buck Scrubbing Bubbles& Automatic Shower...
How do I hook up my Kirby Ultimate G for upholstery shampooing?
Hooking up the foaming device simply blows foam into the job. Here is a shortcut which I find more convenient on my G4 tools. If you have the rotary upholstery shampoo kit, you can just attach the rotary tool to your hose. Then mix your kirby suds into a household spray mist bottle. If you happen to have a mist bottle with a screen on the intake straw it will foam your suds not quite as well as the kirby device, but this way you can store the suds in the spray bottle for future quick use.
kirby suds are designed to be used as foam not liquid so a foamer in the spray bottle helps the process. You do not want to soak the furniture, just apply a light mist and scrub with the air driven shampoo tool on the hose. Then allow to dry and vacuum 24 hours later.
Sep 10, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Foam sprayer will not spray foam!
Check to see if the straw is present and attached correctly inside the jar.
Jun 09, 2009 | Kirby G6 Bagged Upright Vacuum
Fisher Paykel double dishdrawer
pour some vinger in and run it thru a few cycle this will flujsh it out also if you have a hot tub supply store near you can buy a bottle of Foam Down and that will cut the bubbles down so you can wash again
May 02, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Buck Scrubbing Bubbles& Automatic Shower Cleaner  - 2 Pack Logo
702 people viewed this question
Top Buck Home Experts
Donni Steen
Gene Haynes
Steve Allison
Steve Allison
Are you a Buck Home Expert? Answer questions, earn points and help others
