Polk Audio AMR2 Computer Speakers Logo
Posted on Jul 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sound is too low - Polk Audio AMR2 Computer Speakers
Anonymous
Level 2:
Scholar:
New Friend:
  • Expert 55 Answers
  • Posted on Aug 06, 2010
Anonymous
Expert
Level 2:
Scholar:
New Friend:
Answers
55
Questions
Helped
9215
Points
153
Go to START>Control Panel>Sound HQ/Sounds and Audio Devices or something similar. Make sure your speaker volume is up (Move the sliding tab to the right). And that your Speakers Volume is up(A tab on the bottom area of sounds, in advanced tabs, or properties. Slide the tab to the right for louder, left for quieter) and make sure your Mute button is UNCHECKED.
Have a good one :)
How do i fix low volume on pc
No singular answer. Here are some of the things to try, following by links depicting details: 1) Update audio drivers via device manager or 3rd party ware 2) Change sound quality by altering Speaker properties via Sound icon on task bar 3) Change Loudness Equalization of Speakers in Enhancement tab of Speaker Properties 4) Run Audio Troubleshooter 5) Use Windows Volume Mixer to increase sound 6) In Sound, change Communications tab to Do Nothing 7) Try different audio device 8) Try VLC and adjust it to boost volume 9) In Chrome, use Volume Boosting extension 10) Clean speakers 11) Increase Media Player sound
https://www.minitool.com/news/fix-windows-10-volume-too-low.html
https://www.makeuseof.com/ways-to-fix-low-volume-windows-10/
https://www.thewindowsclub.com/computer-volume-low-windows
2helpful
Nokia asha 200 very low earpice sound speaker replaced but same problem
I have a problem with a nokia asha 200 phone that is very low sound for calling to any voice call ,then i am changed speaker but same problem present low sound
Mackie 450v1 when i turn on low cut switch the sound stops turn off low cut and sound returns
Dusty/Faulty switch and/or opamp inside pcb, let me know to help more/.
1helpful
My Polaroid 1911 TXLB 19in television is not working properly. The volume is very very very low. We have a DVD player hook up to it and its been working fine. Last nite was working, shut it off and today...
check the Sounds with Local TV channels.Is it still low?If it is still low sound circuit has to be repaired.if it is ok,sound switching circuit has to be repaired(TV to Video)
2answers
Low does not work, medium and high do
You probably cant fix it, this sounds like a multispeed blower with hi/medium/lo settings. You
can either replace the motor or connect one of the
working speeds to low/med or low/hi. or bump med to low and high to medium.
3helpful
2answers
Sound is low
try to see if the wave volume is on and maximum on the volume panel ( double click on vol icon on tray system (right low) ) ...also see if your speakers are plugged into the proper place ...and are not in the auxiliary out or something like this ...they should be plugged into the green middle out ...if they are simple stereo 3,2 jack ...so ..if the problem its still on ..its probably the sound card...(actually the pre-amplifier on it ..)
2answers
Sound very low. All three graphic sound bars are
the hear piece is faulty or damaged and need to be replaced.
Low sound on my Vizio 50" plasma
Most of HD channel broadcast in 5.1 channel sound. Regular channel broadcast in 2.0 channel sound. You TV only have 2 speakers so you will expect the sound will be low compare with the regular channel.
Hope this will help!
Sound output
This comes under business class range.Note books in this range will be low in sound and multimedia
Very low sound
Have you tried the settings in Control Panel - Sounds and Audio Devices.
The volume of the sound and speakers can be adjusted here - perhaps your main volume is set too low?
Good luck.
Top Polk Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
k24674
Are you a Polk Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
