Kodak EasyShare M863 Digital Camera Logo
Posted on Jul 24, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
M863 lens extends and then immediately retracts
My M863 when switched on the lens extends and then immediately retracts and the camera switches itself off. Have tried recharging and think it's fully charged any thoughts?
Duane Wong
Level 3:
  • Kodak Master 6,826 Answers
  • Posted on Jul 24, 2010
Duane Wong
Kodak Master
Level 3:
Answers
6826
Questions
6
Helped
2862061
Points
20234
Kodak Easyshare cameras use Li ion batteries, as recommended by the manufacturer, which have higher voltages but not necessarily higher amp hours per battery pack.
When I first bought my 14.1 megapixel camera from Kodak, I tried various batteries, including Alkaline, Ni MH, and they didn't work very long before needing replacement or recharging.
This is because the voltage isn't enough on other batteries.
I do not understand why they make it this way, because it fooled me a lot. I thought that since it had a AA format that it would be alright to use AA batteries of any type in the camera. But, this is not so, in my experience.
Good luck getting your camera to work with new Li Ion Batteries.
Note: if the Li Ion batteries do not work, then there is something wrong internally with your camera.
Contact kodak.com to see if it is economically repairable.
Thanks for asking a question on Fixya.com.
Kodak easyshare Z650 lens extends and retracts
I only can think of two reasons. The first, the battery does not have enough power. As a safety precaution it shuts itself down, to avoid damage to the saved pictures. Because if the voltage is to low, it can't write with 100% accuracy.
Second: something is blocking free movement of the lens. This could have a cause inside the lens barrel, and you won't see a thing. It also could be a minute damage on the outside of the lens. Or what sometimes happens while putting the camera on, you touch the lens barrel. I assume you did remove any lens cap attached to the camera.
So if you can't see any damage to the lens barrel, charge the battery and try again.
Zoom lens won't retract on fujifilm f410
This indicate that there will be some problem with your camera Lens. Try to follow these steps to resolve the issue:-
1) Switch the camera OFF and then ON again. (May be your camera lens is struggling to extend)
2) Load new or fully charged batteries.
Else your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Kodak M863
Clean the contacts inside the battery compartment with a cotton swab "dampened" with rubbing alcohol. Do the same to the battery and the charger.
4helpful
2answers
My camera when swited on will switch its self off straight away
Its the lens that is faulty. Cam is designed to shut-off automatically when it is experiencing struggle extending or retacting the lens. Lens doesn't extend while reviewing pictures that is why it is not shutting off.
You need to send the camera for warranty.
Process it @ www.kodak.com/go/stepbystep
Or call Kodak Technical Support 1-800-235-6325 Ext #1 For English #12 Camera Dept. #2 For Service and Hardware Dept.
Thanks,
Lester
1helpful
Lens wont stay open.
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK OoW repair is 48,44 +shipping to the repair centre:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
When i switch my camera on the lens opens but retracts immediately and the camera switches itself off - (it is fully charged)
Possibly the internal battery is at the end of its life and not hlding the charge. Try a new battery if possible.
Camera freezing up
did someone spill some pop or anything near the camera? If so, then you'll need to clean that out with rubbing alcohol
1helpful
The lens will not extend
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage.
thank u
rate me!!!
Lumix lens retracts and extends
Belikes, any external object is trapped in between your Lens Motor and Camera Body. You should consult Authorized Service Personnel to handle this trouble.
After switching on - the lens extends and retracts repeatedly
I had the same issue and thought me Ebay camera was trash. I put the batteries back on the charger over night and it worked properly in the morning. Looked to be a low power issue, but my lens did look like it was all cocked, grinding and stalling. perhaps the camera reset itself with no batteries in it for a few hours> I was very relieved.
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
