SOURCE: Washing Machine broke after power surge
First thing to check is mains filter. have replaced lots on this model!! This is located where the cable comes into the machine.Usually obvious visually if burnt.
SOURCE: Hotpoint Aquarius WT540 washing machine. will not fill with water
Sounds like a timer switch malfunction.
SOURCE: How do I change the door boot seal on a Hotpoint Aquarius WMA31N?
Ok - I will answer my own problem seeing as though I have now fitted it!
1. remove door (2 screws)
2. There is a tensioned wire loop holding the front part of the boot seal in position. - prize off the plastic cap at the 11 o'clock position, all will become clear and you will be able to remove the wire loop.
3. Remove top of washing machine (2 allen screws behind caps at the front.
4. Remove soap dispenser draw and any screws holding the front control panel and top of the door.
5. Remove bottom front plinth (just pull it off) underneath are a couple of screws holding the front panel part of the machine, remove these.
6. Remove front of machine giving you access to the steel band which locks the other end of the boot seal in position. Slacken this band right back using a nut-spinner screwdriver. Pull off the old boot and clean the lip ready for fitting of the new boot.
7. Fit new boot seal using a squirt of washing up liquid as lubricant if needed (mine didn't) to reseat the seal.
8. Refit and tension steel band.
9. Re-assemble front panel, ease boot back into front lip position then refit wire loop using a suitable pair of pliers/molegrips to crimp the retaining plastic cap back in situ.
SOURCE: My Hotpoint Aquarius WF430 1300 doesn't complete its cycle
If your lights are flashing, use these codes to pinpoint the error.
These codes are reading from the top neon down.
F01....OFF, OFF, OFF, Flash, OFF.
F02....OFF, OFF, Flash, OFF, OFF.
F03....OFF, OFF, Flash, Flash, OFF.
F04....OFF, Flash, OFF, OFF, OFF.
F05....OFF, Flash, OFF, Flash, OFF.
F06....OFF, Flash, Flash, OFF, OFF.
F07....OFF, Flash, Flash, Flash, OFF.
F08....Flash, OFF, OFF, OFF, OFF.
F09....Flash, OFF, OFF, Flash, OFF.
F10....Flash, OFF, Flash, OFF, OFF.
F11....Flash, OFF, Flash, Flash, OFF.
F12....Flash, Flash, OFF, OFF, OFF.
F13....Flash, Flash, OFF, Flash, OFF.
F14....Flash, Flash, Flash, OFF, OFF.
F15....Flash, Flash, Flash, Flash, OFF.
f16....OFF, OFF, OFF, OFF, Flash.
F17....OFF, OFF, OFF, Flash, Flash.
F18....OFF, OFF, ON, OFF, OFF. Fault on control board, check Eeprom.
these are the codes and this is what they mean
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
also try checking this manual
http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/WFseries_19504110305_Jan05_book.pdf
