you must see the schematic diagram coming with your treadmill, or read your owner manual, and follow the instruction in section assembly or parts manual God bless you
I will recomend Read your instructions or user manual, section unfold or assembly the treadmill.
If you do not have the owner or user manual, go to the web page. www.proform. com then customer service, and then parts & manual, give your model, serial number, and download free, and ready.
However you must take carefully and pacience with this. sincerely.
The short answer is Yes , it will not run without the key being in place. The key lanyard clip are designed to shut down the treadmill should the user fall while using the treadmill to help prevent serious injury. The long answer and I would not advise anyone to do this , but it is possible to take the console apart and bypass the safety switch. I would only do this if I did not have a key and wanted to test to see if the machine worked . Some models can be tested with a round magnet in place of the key others need a plastic card trimmed down to fit the slot . Hope this helps and remember safety first !!
You have gas shocks on each side of the unit need to see if they are dry and causing the unit not to fully fold down use a little machine oil on the rods this should take of it if not, either the shock are defective or some how you manage to fold the unit when the incline was not at its minimum.
1) engage key the look at incline display needs to be either 0 or 1 degree
2) if shock are defective replace shocks.
Hope this help!!
To calibrate the speed and/or incline, please refer to the instructions that are under the motor hood cover or are mounted on the inside of the belly pan. Be sure to unplug your machine. If the instructions are not there, please contact our customer service department at {~1-888-533-1333} while you are near your machine.
