HP OfficeJet G85 All-In-One InkJet Printer Logo
Posted on Apr 22, 2008
Carriage Jam I keep getting error message to OPEN DOOR CLEAR CARRIAGE JAM and then PRESS ENTER. How do I fix it? There is no apparent "jam"
  • abbabb Sep 15, 2008
    My carriage has jammed and I can not locate the reason why. I had a paper jam and removed from the back as normal and now the carriage will not move freely its stuck in the middle as if I was about to remove the cartridges. Please help.
A
Anonymous
Make sure you can move the print cartridge holder freely and that it isn't being blocked by anything inside the printer, also check if the cleaning station is in the right position, maybe it is locking the cartridges.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 22, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1662
Points
A
Anonymous
5 Related Answers
Anonymous
  • 152 Answers
  • Posted on Feb 28, 2008
SOURCE: open door, clear carriage jam and press enter
eject black and colour both cartridge after that power on
if carriage block running properly for first intilization so problem
is your any one or both cartridge fail
if carriage block not move first time so check for encoder strip is
ok or not
Anonymous
  • Posted on Jan 01, 2009
SOURCE: HP Officejet 5110 - Carriage Jam Message
I have an Hp Officejet 5110. I have an error message saying "Open door,clear carriage jam, then press enter". But where is its door? How can I clear the carriage jam?
I tried pressing the # & 6 at the same time, but the error message still there.
Anonymous
  • 5 Answers
  • Posted on Jul 30, 2009
SOURCE: i keep getting a message: open door. clear
Dear,
Its a problem of purging unit it is in a right hand side of printer clean the surface properly and then check the printer.
bye
wasim
Anonymous
  • 68 Answers
  • Posted on Feb 01, 2010
SOURCE: error message= open door clear carriage jam and
I think the message is instructions, as in
(1) open door (2) clear carriage jam (3) press enter
So there is something internal to the printer that makes it think it has a carriage jam, piece of paper under a sensor, dirty or stuck sensor.
If you can't find it using a bright light, try canned air.
Anonymous
  • 52 Answers
  • Posted on Apr 15, 2010
SOURCE: clear carriage jam
The carriage assembly is what the ink cartridges moves on. The silver bar that runs through the cartridge holder must be oiled. Put two or three drops of thin oil oun iether sides of the cartridge holder. This should clear the "carriage error"
Good Luck
Testimonial: "Very helpful. My first reaction was to panic that no one oould repair an older printer but this advice got me to calm down and fix the problem."
I have a HP 5510- it show to have a carriage jam. I don't know how to fix this.
If you get this error message "Open door. Clear carriage jam, and then press OK" then watch this video on how to clear the error (it's in korean but the visual part will help you out):
I just changed the (2) ink cartridges in my HP PCS 1610 All-in-One HP printer and now get an error message "CARRIAGE JAM - OPEN DOOR. CLEAR CARRIAGE JAM, AND THEN PRESS OK." I don't see any jam...
Have you tried moving the carriage to see if it really is jammed? Maybe you haven't put the levers down properly on your new cartridges....remove them, see if the carriage slides, then refit them and check the carriage again. You wont visually 'see' a carriage jam,; you have to try moving it. By the way, if it doesn't move, DONT force it to try and overcome the jam try and reason out why it doesn't move.
Hope this helps!
nicam49
1helpful
Clear carriage jam
Good Luck
Error message= open door clear carriage jam and
1helpful
I am receiving an error message on my HP Officejet 6110 printer screen that prevents the printer from functioning. The message is "Open door. Clear carriage jam and then press enter." I've tried opening...
yes, that is a carriage jam and not paper, the grinding is from the clean station that gets blocked with dried ink and cant move. you need to open the printer and clean the ink off of the clean station so it can clean properly and not cause a carriage jam.
1helpful
2answers
4answers
HP Officejet 6110 "Carriage jam" error message
Get Instant services and solution for your HP Printer support. Printer services USA is here to fix your printer anywhere anytime, just call us on our toll-free printer number +1 866-918-4391 or for more visit our official website
https://www.printsupportusa.com/
2answers
Carriage jam message
unplug the power cable without powering the printer off,
press and hold # & 6 on the printer ... while holding these two keys connect the power cord and do not release the keys till the screen turns off. press the power button to turn the printer on ... it ll go through a reset and it ll be working fine, if the issue persists let me know
thanx
1helpful
How do I get fix a "carriage jam"?
I was able to run run a piece of photo paper through a couple of times and printer now seems to be working again. The theory was that running a heavy piece of paper through might help clear little piece of paper that was not visible. The photo paper is less likely to tear if it gets jammed too.
2answers
k24674
Grand Canyon Tech
Grand Canyon Tech
