Samsung LTN226W 22 in. HD-Ready LCD Television Logo
A
Anonymous Posted on Feb 13, 2018
Samsung lcd 32 inches screen. The volume turns down to zero by itself. The remote control looses control. Control through remote control keeps coming and going intermittently.volume can be turned up manually or through remote control when it has control. But it turns down to zero every time
Alex Cyrus
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Feb 13, 2018
Alex Cyrus
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
660
Points
25
I also faced a similar problem when i was watching a cricket match. First, check your remote control. MyLiveCricketv com Live Cricket Streaming Watch Live Cricket TV Online
Steven Brandon
Level 3:
Master:
  • Samsung Master 462 Answers
Steven Brandon
Samsung Master
Level 3:
Master:
Answers
462
Questions
0
Helped
117738
Points
1705
Try removing the batteries from the remote after you set the volume, just to determine if the remote is causing the problem or not. I have seen stuff spilled on remotes and they just go crazy.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
5 Related Answers
Anonymous
  • 58 Answers
  • Posted on Mar 12, 2008
SOURCE: DIGITAL SOFTWARE UPDATES FOR SAMSUNG 32 INCH LCD TV
you cant force updates, and they may never be another update. updates are only made when there is a problem with the software in the tv
Anonymous
  • 29 Answers
  • Posted on Mar 15, 2008
SOURCE: 32 inch Samsung LCD TV has no picture
do this test, turn tv on and touch the screen if you can see light in the background it is the panel if no back light is present then it is the power board.
A
Anonymous
  • Posted on Mar 18, 2008
SOURCE: SAMSUNG 32 IN LCD LE32R73BDX (MASTER RESET)
i want the codes too my dtv is locked up
Anonymous
  • Posted on Mar 18, 2009
SOURCE: 32 Inch Brand new Samsung 32" LCD showing subtitles / no volume??
I had a similar problem, checked all of the TV's control settings only to find out that my cable box had an independent "mute" function that automatically turned on the closed captions when activated. Once I found that and turned it off, all was fine.
Anonymous
  • Posted on Jun 21, 2009
SOURCE: Samsung 32 inch remote control problem
I had a similar problem. Take the batteries out of the remote, press down on the number 5 for about two minutes the put the batteries back in. This worked for me.
(I got this tip from a telesales advisor. I was close to buying a replacement remote but this tip worked. Hope it does for you. I'm not sure on the science part of it but it basically resets the remote. Good luck)
I have a 60" LCD LED Samsung Tv and I am getting static noise/crackling noise that doesn't go away even with the sound off. The only way to get rid of it is to turn the tv off completely.
Using the volume control buttons on the television itself (not the remote) turn the volume all the way down to 0.
Using the volume controls on the Digital box itself.
Turn up the volume until it is at the maximum.
Using the television's volume controls again; raise the volume to a comfortable level.
If you are still experiencing the audio problems on this television, it is possible there is a loose connection on the television.
2answers
Volume keeps going down to zero
Emerson volume keeps going down Questions & Answers ...
www.fixya.com > Forum > Tags > volume keeps going down
Emerson volume keeps going down related problems. Ask your Emerson ... myEmerson TV. It turned itself down to zero and stayed on the screen and wouldn.
Emerson Flat Screen TV volume trouble? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Aug 10, 2011 - My Emerson 32 inch does similar things, volume just goes to 0-100 and stays there. ... Why is the volume on my Emerson flat screen TV not working and how could i fix it? Whats wrong with my Emerson Flat screen tv? Why is the volume on my Emerson flat screen TV not working ...
Jul 13, 2013
My son has an Emerson tv it keeps turning down by itself. Anyone ...
Aug 24, 2006
More results from answers.yahoo.com
Emerson TV problem ' Techlore
The volume onmy Emerson TV turned down to zero. I turned it up with the buttons on the TV it turned back down to zero. The zero volume stayed on the screen.I turned the volume up withremotenoresponse.
The main system control memory IC to this TV is damaged. Replace it. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
I have a 32 inch Samsung LCD TV. For some unexplained reason it keeps turning the volume down by itself. I have tried the obvious, like taking the batteries out of the remotes and then turning the volume...
Warning! Pull out the cord first!!! Open the TV take the tester and check over the mini board with the buttons, there might be the Vol- button in shortcut, or get some water. If its short, must replace, if there are water/ liquid/ oxyds traces, take a toothbrush, put a little of alcohol, and gently clean the place, after that dry it with a hairdryer.
Samsung le40r74bd problem
I just had this problem with my 3 year old 32" Samsung LCD. The volume would go up and down by itself, normally just constantly going up even when it reached 100%.
I thought it might have something to do with the volume buttons on the TV itself so seeing as it was out of warranty anyway I decided to unplug it and open it up.
I gave it a good clean and I disconnected the cable for the panel of buttons on the LCD itself (volume, menu, channel etc) seeing as I never use them anyway. I then put everything else back together and tested.
It seems to be working fine now. Previously (for the past 3 hours) ever time I turned it on the volume level would come on instantly and stay on until I turned the TV off. So I’m quietly confident the problem has been fixed. But I must admit it’s only been 10 minutes, so who knows, it might come back.
2answers
The volume control is stuck
you didn't mention even using the remote. any way if it does not control even doing manualy or with remote control contact the dealer of you tv and discuss the problem. This could happen now a days LCD tv's has a program to operate. i suspended the program of your tv has reset.
Telvision Problem
Do the controls on the tv itself work or just the remote? If it's the remote mabey it's defective. I would look on the Ilo site and see if they recommend a universal remote for their models ( or just getting yours replaced ). If the problem is within the tv, I'd look into the warranty. Sorry if this wasn't any help.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
