SOURCE: sony trinitron wega 36 inch
break the wega into tiny little pieces and it's easier to get out of your house!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
If you are not a professional Electronics guy,it is beyond you to tackle this problem. otherwise log on to www.free service manuals.com and see the SONY Blink codes and also download the service manual.best of luck
SOURCE: Sony Wega 40" TV will not turn on, standby light blinks 6 times repeatedly
Hello,For model KV-40XBR800,
Pls check following area.
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high
turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
And NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks.
Good Luck
Dals123
SOURCE: STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
SOURCE: TV won't turn on, standby LED starts blinking
HI, this is the result of an unstable power sector in this unit. the fly back is malfunctioning and, you will need to replace it asap. i will list the part number below and a link to a site as well. you can purchase this part on-line if you wish.
FBT ASSY NX-4521//X4
Sony Part Number: 1-453-310-11
CLICK HERE TO ORDER
