SOURCE: Dehumidifier Error?
Your bucket full switch may be defective. If you are capable, bypass it since you are draining to another place other than the bucket.
SOURCE: Goldstar DH504EL Dehumidifier
hey i just got paid by some guy to haul away a broken fan(currently fixing) DH504ELY5 dehumidifier on my model with bucket removed front facing you reach to the far right the orfice there drains to the bucket id only assume just get the proper od hose(even clear) from a hardware store attach it and it should be fine- take back panel off(plastic 6 screws and youll have to gently pry the "clips" out of the steel back-dont worry if one breaks the screws will still keep the back on on reassembly) there is a hole with a foam kinda adhesive tape over it it is perforated for the purpose of an external hose feed it through there and out of the hole thats in the middle of where the power cord winds up for storage-all will be a straight shot on reassembly no twists or turns try that should do the trick and you can keep the bucket on there:)
SOURCE: goldstar dehumidifier
The hose connector does not drain the bucket, it drains the condensate before it enters the bucket. Tube passes through back of dehumidifier by the cord wrap area. (you may have to remove a small cover)
SOURCE: ghd30y7 goldstar dehumidifier
We came home to this problem the other day, water all over the basement, leaking out the bottom left side, nothing in the collection basin but plenty would spill out if I tipped the unit forward. After searching the web and these forums I theorized that the coils were frozen. I let the unit thaw. No luck. I removed the faceplate and discovered thick, wet silt had filled the internal collection plate and was clogging the drain. I stuck a pipe-cleaner through the drain and the problem was fixed. Took some paper towels and cleaned the whole thing. Works like new. I assume the unit will need to be cleaned regularly to keep it going. To remove the faceplate, unscrew the two phillips' head screws under the faceplate along the sides, then take a flat head screwdriver and pop the tabs holding the face on, one tabe along each side. There are also two tabs on top, but you don't need to mess with those, as they simply act against gravity. Whole thing just clips back together after cleaning. I have no idea if this voids the warranty.
SOURCE: Are you supposed to put water in the bucket of the
The dehumidifier condenses the water on its coils and then it drips into the bucket. Dump out all of the water when the bucket is full. This model has a light that tells you when it is full. If the dehumidifier gets ice on the coils, it needs repair (low refrigerant).
I hope this helps.
