Resetting the Recorder to Factory Settings
1. Make sure that the recorder is on
2. Press and hold the STOP button and STANDBY/ON button.
The recorder turns off with all settings reset.
I have been told LSI NG on my Pioneer 510 HDD Recorder refers to failure of the large Scale Intigraton Chip (LSI for short) so it is saying the L.S.I. Chip is No Good.
Some have commented elsewhere this might be a failure of a hard disk leading to this and to try and change the HDD out and see if the failure continues as this may cause the LSI statement...
My service tech just told me this is plausible but unlikely and the Pioneer 310/510 DVD Recorders are getting old and the LSI chips are starting to fail on them.
I regret to say the recorder is probably failing on you due to it's age. My tech commented to me these are supposedly good for five years and their current age is almost 11 years.
Remainig use life depends on the unit and how much it has been used. We got into this with a failed DVD burner on our unit which you use to burn from the HDD Hard Disk in the 510 (the 310 is a DVD Recorder only).
Just a note on servicing these units. If you remove the DVDR or HDD you then need a service remote and service DVD on these units to reset the code in the units or they will not work.
If you open them up and start disconnecting the drives and don't have these tools you will not be able to reset them and the units will not work even if there is no problem (so you have been forewarned about this).
I'd check on line for a refub unit as there are very few qualified techs to deal with these and many lack the tools for these old units. People like them because they have many great features but are no longer made. I was told all of the 510's were made within six months in I believe 2003 or 2004...
yes, and also you can hook laptop to tv, mine is hooked to a 9 foot projector screen, call 4 free 3363926682 depends on what inputs u want conect 2 for cable suggestion God Bless
I've seen this problem somewhere before, ran across it on a service call or something and I just can't remember where.. Just getting old I guess..
You should have a "Return" button on the remote. Press it and the "2"... That should allow you to access the unit again. What you've done basically is set the unit up as unit 2 and you could have as many as 3 identical units all operating from the same remote. So, Pioneer, in their infinite wisdom decided to make three specific designation points and allow you to switch the remote to access each one without disturbing the rest...
If this doesn't solve the problem you might try calling Pioneer support, 800-421-1404 and they should clearly be able to help.
Good Luck
Bill
