Olympus SP-320 Digital Camera Logo
Posted on Jul 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Battery charger for olympus sp-320 - Olympus SP-320 Digital Camera
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 2 Answers
  • Posted on Jul 26, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
Questions
Helped
463
Points
The SP-320 uses standard AA batteries, disposable or rechargeable. panasonic cgr-d220 battery
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Olympus Master 102,366 Answers
  • Posted on Jul 23, 2010
Olympus Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10444535
Points
622693
The SP-320 uses standard AA batteries, disposable or rechargeable. If you want to use rechargeables, you should be able to find chargers at any department, electronics, or office-supply store. You can't use the camera itself as a charger, however.
2 Related Answers
Anonymous
  • 122 Answers
  • Posted on Aug 23, 2010
SOURCE: I need an instruction manual for an olympus sp-320
http://www.olympus.co.jp/en/support/imsg/digicamera/download/manual/sp.cfm
Anonymous
  • 563 Answers
  • Posted on Nov 27, 2010
SOURCE: My Olympus SP 320 now has a blue 'Busy" screen for
Hello.
Try to reset the camea, and check if that can get rid of the Blue busy thing on your screen.
2helpful
I lost the battery charger of my olympus fe-320. Can i charge it using the usb port ?
No, you cannot charge the battery in the camera via the USB port. You need to use the LI-40C or LI-41C charger or equivalent.
One source for a replacement charger (along with a battery and a camera case) is
http://www.overstock.com/Electronics/rooCASE-Olympus-Black-Nylon-Case-and-LI40B-42B-Battery-Kit/5285636/product.html
Hello.
I have a problem with power on Olympus SP-550UZ
Try using regular batteries. I did with my camera and seems I can go a lot longer on the regular batteries verses the re-chargable ones
My sp-320 wont upload pics to the my PC!
Use a card reader instead of the camera.
1helpful
The zoom of my SP-320 is not working anymore. What can I do? Hanno
Hello
Thank you for using FixYa for your problem
Always check the batteries first but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
2helpful
2answers
I am not getting the suff.no of snaps as batt is getting down for olympus( sp-350) . i have tried several type of AA 2500 mAh Ni-MH battery and purchased new LCD (simpex) charger.then also same.also when...
The problem you describe is frequently due to corrosion on the battery contacts inside the camera. Remove the batteries and wipe the inside contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe the ends of the batteries and replace them in the camera. This clears up the problem about 90% of the time -- I hope it works for you.
Downloading pictures from Olympus SP-320
you will need a USB camera lead to plug to the PC then you can copy all of your pictures to the computer
kind regards and please don't forget to rate us
Power on
I have same problem, Im gonna to try put a regular charger,then wi will see
LCD panel cracked
The price to have the LCD replaced would probably cost 75% of a new one. If you can do without the LCD and it downloads the pictures to your PC, at least you've got something.
That camera has a viewfinder, so you can still take pictures, right.
Sorry about the bad news.
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
