Re: Cant find radio unlock code.. Looked in fuse box back...
You need to get the serial number off the sticker attached to the radio. It will require pulling apart your dash. Call an Acura dealership with that serial number and they should be able to provide you the code. Or you can take it directly to the dealer but you will be charged labor.
Radio theft protection page 372 owners manual
Your vehicle's audio system may disable itself if it is disconnected from electrical power for any reason. To make it work again, you must enter a specific five-digit code with the preset buttons. Because there are hundreds of number combinations possible from the five digits, making the system work without knowing the exact code is nearly impossible.
Page 563 - 569 fuse box locations http://techinfo.honda.com/rjanisis/pubs/OM/K41010/K41010OM.PDF
How To Find Your Acura Radio Code https://www.youtube.com/watch?v=6AzLh4FeOC0
you might get lucky with this one. should not hurt to try.
How to bypass unlock radio with out entering code on Honda or Acura. https://www.youtube.com/watch?v=ZWLVZ4QU-7g
Acura TL (2010 - 2011) - fuse box diagram https://www.autogenius.info/acura-tl-2010-2011-fuse-box-diagram/
If you have no power to radio at all you may need to check all the fuses I do not see a fuse labeled radio but you have 3 fuse boxes.
Drivers side, passenger side and under hood.
Code is at 3 places in your car, hopefully one is still there . look in orig. book, front or back s/b written. second in glove box, a white sticker. never there! best bet it under cover of fuse box in front under hood passenger side (R) has relays for ABS, should be a sticker under lid. usually still there. otherwise pull radio and get serial # . good luck.
The code could have been written in the back pages in your manual or there may be a sticker in the glove box or the inside of the fuse box cover. The dealer will charge you dealer price and all there going to do is the same thing i am going to give you. www.radio-code.com. Before you go to that web page, try 0000 first. Good luck and hope this helps. Keep me posted, be glad to help.
look on the side of your glove box on the casing of the glove box compartment and if there is a sticker with i think it is a 4 or 5 digit code press that code in. and it should unlock. if not you can always pull the stereo out and get have the dealership look it up and give you the code. if you have the owners manual they normally put the code in the back pages of the owners manual as well. if you cant find it post another problem i will try to help
