If you’re hearing a fast knocking or a fast grinding sound, then it is your motor going bad. This will result in an LE code and the unit will no longer work as this gets worse.
You can get a replacement sump assembly that has the motor and all new sensors to resolve this issue.
Good Luck.
You can purchase the main pump seperately and install yourself. The trick is to remove the "drum" section from the plastic base so that you can install the new pump easily.
Please help
