Find great deals on eBay for Shower Door Hinges in Shower Doors and Stall Enclosures. Shop with confidence. ... Shower Door Hinge Wall Mount Hinge 8-12mm Bracket Frameless Wall to Glass ... This item is being sold by eBay Top rated seller. ... hinges. They have never been used but do not have hardware with them.
The wall was not perfectly plumb before the fixed glass was attached. The top needs to be shimmed out 3/16 and resealed against the wall. On the other hand 3/16 is not much of an error. Maybe no one else will notice it.
You can use WD-40 on the pivoting part, spray a little on the hinge part when the shower door is mostly closed and also mostly open, open and close the shower a few times so the stuff can penetrate it, and Make sure to tighten any loose screws, and brush out any grime using a toothbrush and liquid soap. Wipe the drops of wd-40.
Ace Hardware sells that door and you will need to see if they can order the parts but it looka like they sell the doors 36" size so when you order you will need to order for the Sterling Plumbing 1500D-36S "Vista Pivot" Shower Door Fits Openings 31 -1/4" To 36" H 66" . Now if you have not completely finished the shower you could always make the door opening fit what you have.
this is your mission should you choose to accept it,...one magnet comes out, (usually the door one), what ever one it is, slide it out and put it back in top to bottom-bottom to top, and you'll be all set. let me know if you need more help,......good luck.
you can fix this problem by loostening the clamp screw and putting locktite sealer(you can purchase locktite from hd or lowes locktite is not the only product you can call a glass supplier and as for recommendation) Be sure to read the directions on the tube I use it to seal joints on refrigeration threaded parts. Make sure it will adhere to glass and metal also review the clean up solvent when you do this place a wood wedge at the bottom of the glass dooor and the threashold to support he weight until the sealer driese
Steps
1 Place wood wedge/block under door where non hinged side meets wall
2 losten top hinge(inspect bottom hinge to make sure it is snug and the glass dor is all the way into the hinge
3 You may have to remove the top hinge completely to get enough of the locktite on the metal and glass place the locktite on the hinge flat plate and the glass
4 recheck gap where door meets wall( I sometimes use paint stirs(wood) as shims to keep space between door and wall consistent
5 tighten top inge screws( you can put locktite on the screw threas also
6 Clean excess locktite and wait suggested time by instructions on tube
