LUBE THE deck belt,+rollers bearing front and back. test the drive belt motor, and replace the belt if necessary. However if the problem persist, TIME to replace the deck belt God bless you
Dear Sir: See this block diagram that i did for you help. you will only 2 wires, one go to the input the another to output it does matter which color go to the input or output.God bless you
I have recently bought from a friend a reebok fusion treadmill. However due to a break up the treadmill was dismatled and put into storage and now they cannot remember where the wires go. Can anyone help?
There should be a knob on the post holding the platform in the vertical position. Press the platform slightly. Pull out on the knob and let the platform fall (gently) back toward you.
I have the same problem. I phoned Reebok Tech Support 01908 512244. It is a timed icon to advise the deck should be lubricated. If you have done so / do this regularly you can ignore it. To remove the icon follow the instructions they emailed me. Hope this works Cheers John
Please follow procedure below: 1. Keep power on and remove the safety key 2. Press and hold incline down and speed down, at the same time insert the safety key 3. You can release the “Down” buttons. (you will now hear a beep) 4. Press Speed up 6. Press stop. You will now hear a beep and the icon will disappear
looking for a downloadable manual for a reebok rev 11301 fusion treadmill
