Only the right half of my screen on my dell inspirion 9200 is showing. I cannot see the start menu or half of my icons....is this a graphic card problem?
Re: only half of my screen on my dell inspirion 9200
You can try to connect an external monitor to your system then toggle FN+f8 if you see the screen good in external monitor it means the graphic card is ok then you have to replace the LCD panel.
Hi Msdco1, 1st try fixing your laptop..... The link below is a YouTube video showing 3 ways on how to fix your laptop, Also there's videos down the right side of the link that may help as well, I hope this helped....CHEERS.. ALL LAPTOPS DISPLAY NOT COMING ON BLACK or BLANK SCREEN DIM DISPLAY
Yes! but it is a good idea to hook a spare monitor to the video output first to make sure there is no problem, if okay! replace the LCD screen. Go to www.ebay.com Type: make and model of the laptop and refine search to screen, a list of sellers will pop up showing the prices.
If the drive is showing an error (or is missing) in device manager, do the following: Start Registry Editor (Start, Run and type in regedit then click O.K) Locate the UpperFilters value under the following key in the registry: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} On the Edit menu, click Delete, and then click OK. Locate the LowerFilters value under the same key in the registry: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} On the Edit menu, click Delete, and then click OK. Quit Registry Editor.
Try right clicking on the desktop then selecting "properties". A window should appear. Click the "settings" tab at the top of this window. In the settings screen is a slider bar for screen resolution try sliding this to different places and clicking the apply button at the bottom of the screen until it is right. If this does not work go to start then control panel. If control panel is not in classic view switch it to classic view by clicking "Switch to classic" in the left hand column. Next click the icon that says "system" below it. In the window that opens click the tab that says "Hardware" in the hardware window click the "Device Manager" Button. A new window will open that has a list of things. There should be an entry in the list called "display adapters". Click the plus sign beside this. It should then expand and have a subentry for your display adapter. Right click on this sub entry. A popup menu will appear in the menu click "uninstall". A warning message will appear saying you are about to uninstall it. Click "OK". Now close all your open programs and restart your computer. When your computer restarts it should detect your screen as new hardware and configure it properly.
P.S. all directions are for Windows XP. Please rate me! Thanks.
uslay the mobo on these u can replce just the video dell has online guide to open it right up easy shows u how to pull it out its not to bad but u will need a t8 star tool sears u can buy one usally when screen goes out bad mobo o these ok they get hot best to open it up clean all dust out re greese the heat sinks on cpu and video but usally power chips on mobo go bad on these ones sell it on ebay like i did
