Seagate 320GB FreeAgent Pro FireWire 400, USB 2.0/eSATA Data Mover Drive Hard Drive Logo
Posted on Jul 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can i partition my 320gb sea gate ext harddisk
How can i partition my 320gb seagate free agent go ext harddisk . I have windows xp
Anonymous
Level 2:
New Friend:
  • Expert 75 Answers
  • Posted on Jul 22, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
75
Questions
0
Helped
15781
Points
161
You can partition your hard disk while installing windows xp
and if you want to parition your hard disk after installing your windows,you will need third party softwares called parition magic which are free to try,but you will have to buy those softwares to use it,so its better to paritiyion your hard disk while installing windows
1helpful
My seagate freeagent go 500mb cannot be recognized by my laptop. using sea tools windows scanning for supported drives is taking such a long time as the ext drive cannot be detected by the laptop.
Have you got any drivers installed for Free Agent? If you have an older OS you will need to insert a system disc for the Drive, or else it won't recognise it.
1helpful
2answers
320GB seagate freeagent, cant open some of the files.
If you have the ability and space then recover any files that you can
use the RUN option from the start menu
now type in "cmd" then ENTER
Now in the black box that appears type "chkdsk x: /f /r" and press ENTER
The "x" is the drive letter of the drive you wish to check
It may take some time but this will try fix any errors it comes acrosss and you may have to re-start to complete the task.
Now remove any more files that you can.
Use the RUN command again but this time type "compmgmt.msc"
Select Disk management
Make sure you freeagent is listed here.
Right click and select "Format"
Select NTFS as the file system
Do not tic any other boxes
Click OK
When it is done you can move the files back to this drive.
It is quite possible you hit the limits of the FAT32 file system which would have caused the types of error you saw.
1helpful
2answers
How to partion seagate Free Agent Pro in Windows XP
First make sure that you have a bootable Windows Vista installation DVD, as you will be unable to use your computer if you don’t. Next, download the GParted Live CD and burn it to cd.
Boot off the GParted cd, and you will see your hard drives in the drop-down list. The first drive is typically your boot drive, but you can check the Flags column to make sure.
Next you’ll need to right-click on the partition and choose Resize/Move from the menu.
Now you can either use the New Size textbox, or just click and drag the partition to make it smaller (or bigger). When you are done, click the Resize/Move button.This doesn’t immediately apply the changes, though. You can make other changes to your partitions and then when you are finished click the Apply button.Depending on the amount of data and the speed of your computer, it can take quite a while to resize the partitions. On my computer it took more than 30 minutes.
Once it’s done, quit, remove the live cd and then reboot your computer. Unless you are very lucky, you’ll be greeted with this horrible error message saying “Windows Failed to start. A recent hardware or software change might be the cause.”
Hope this helps!
3answers
Aspire 6930 has 320 GB harddisk,i faced some problem with Avasti Antivirus n i formatted the system to run my system smoothly, but now the problem is harddisk is showing only 128 GB. that too the partition...
You can Reformat the system and REMOVE all partitions. Windows setup will create a new partition from available drive space. If you need to save your data,You can also use a utility like partition Magic and resize the partition. There is a trial version available at no charge. just google "partition magic"
Sea gate ext drive started making clicking noise will not connect
It is still under warranty. Contact Seagate about this matter. They should replace it for you at no cost.
2helpful
Disk manager for seagate 160 gb sata barracuda hard disk
windows xp setup not creat the partation.
and not show the tha harddisk,but harddisk are showing the bios setup.
my system is ACER ASPIRE tower Casing.
Hard disk not detected
The problem is that u have done partitions for 160 GB harddisk, so do all the partitions of 40 GB or less than that.
Top Seagate Computers & Internet Experts
Sean Wright
Sean Wright
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
