My Fridgidaire just popped my breaker downstairs. I unplugged the stove from the wall and switch my breaker back and the breaker hasn't popped since. Once I plugged my stove back into the wall, it popped the breaker again and sparks came out from where the plug goes in. Is there any type of ground that could be defecting this? I pulled of the back panel to make sure everything was tight.
This sounds like a main control problem. More specifically like one of the relays is shorted. You will need to acess the main control and carefully inspect it for any burn marks. If you don't see any disconnect the main power supply wire going to the main control. Then plug it back in if it trips the breaker the problem is in the power cord or wiring from the cord junction to the main control. If it does not trip the breaker the problem is the main control. Here is a link that should help http://appliancehelponline.com/ovenerc.html
