Projector has been overheating the last 6 months. Never had this problem in 3+ yrs of use. No dust in vents, projector is never out of case except when in use which is approx. 2 hrs / week.
Its getting old...and generating more heat...
There are fans inside the projector that **** in ambient
air and blow it across the parts...A quick fix might be
to lower the room temperatrue a few degrees...or
you could get a small fan, place it along side the projector
and have it blow additional air into the projector...
The projector is running at borderline temperature...
Also, make sure it is on a flat hard surface...and not
resting on a cloth or towel or rug...there isn't much space
between the bottom of the projector...to **** air in...and it
needs all that space...
You may want to make sure the AC line voltage is 110 -120 VAC
even a slight drop in this voltage will cause the projector to run
less efficient which means running hotter...
