Problem often occurs on a computer display, usually the problem as a hardware malfunction.
way to identifying it is to perform tests on computer hardware (troubleshooting)
> Sweep ram slot with a small brush or small paint brush is not used (new)
> After cleaning the ram slot, use the eraser to clean the copper surface on the ram you are.
> When you're done, plug the ram in the slot. (If you have a new ram to do the troubleshooting is better)
> Reattach the power source on your computer and then switch on your computer.
> Still not working?
> If you use the display card, remove the display card and do the same as you did on your ram and ram slots.
(If you're not using the display card, the better you get the display card to make the process of troubleshooting)
>Turn on your computer.
(If your computer is still experiencing the same problem though has to do the troubleshooting on the display card)
> Get at / ATX new power supply to do troubleshooting, (damage to the power supply will also cause the computer not display
If the computer still can not function normally means that you have the problem still appears,This requires you to perform more detailed troubleshooting process.
Firstly, you need to provide a motherboard and processor is still working (new) to do this process.If you already have all the equipment, you can start to make the process of troubleshooting your hardware one by one.I believe there is enough equipment for you to perform troubleshooting, problem you will be able to identify you and you will be able to solve by itself.
Hope this can help solve your problem.
thank you
