Cleaned the glass and light bulb. but still the problem persists.
Scanner errors are as follows for that model:
Scanner error #
1 = dark find
2 = LMW temp find
3 = bulb warm up from off
4 = bulb warm up from coarse
5 = cal label find
6 = doc original find
7 = LMW final find
8 = cal label find after scan
9 = cal label find prior to standby
10 = doc original find prior to standby
11 = bulb warm up from standby
I would see if there is an original on the flatbed glass (platen), or if something is obstructing the scanner view.
If the error persists, replace the scanner
assembly or the formatter pcb
1. Clean Glass Scanner Bed.
2. Try the NVRAM INITZ reset procedure. REF
3. Remove paper scrap or dust obstructing scanner or sensor. REF
4. Clean sensor / remove the glass and clean the bulb and mirrors. REF
5. Scanner Bulb is not getting to the alignment area.
Information found @
http://wiki.robotz.com/index.php/HP_LaserJet_3055
Regards
Mike
HP Laserjet 2840 all-inone printer shows scanner error # 3 and scanner error # 5
