Kyocera FS-720 Laser Printer Logo
A
Anonymous Posted on Jul 02, 2010
Printer FS720 Kyocera: both leds on both off for
Printer FS720 Kyocera: both leds on both off for few seconds both leds blinks 3 times green led blinks 2 times both leds blink once freen led blinks 2 times
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 07, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
487
Points
Read here :
http://www.fixyourownprinter.com/forums/laser/64772
Toshiba regza tv went black while watching cable tv. Unable to view via antenna or fire tv. Power light blinks three times and then nothing for a few seconds Unplugged power strip for no results.
The LED on the left blinking green 3 times is power-up, the LED on the right blinking green 3 times is what Toshiba calls a "BUS Error" which basically means a hardware fault.
Credit...
10/08/2015 by Bill Wessendarp
Kyocera fs 1030d: first sequence: 1.led:green
THE PROBLEM IS THE FUSER, YOU HAVE TO OPEN THE ENTIRE TEAM AND IN THE BACK OF PART WHERE IS HEATS UP THE PAGE, BETWEEN ROLLER GREY AND ORANGE, ALLI THIS FUSER. HIM REMOVING THE ENTIRE PIECE THIS SUBJECT TO TWO SCREWS, YOU MUST DISCONNECT THE CABLES (THREE PAIRS), THE PIECE THAT YOU JUST EXTRACTED HAS TWO SCREWS THAT HOLD A BONBILLO THAT IS INSIDE THE GRAY CYLINDER, THERE BELOW YOU WILL SEE A SMALL WHITE PIECE THAT IS SUSTAINED BY TWO SCREW WHICH ARRIVE TWO CABLES, THE DRAW AND THEN TO THE WHITE PIECE WITH A FINE NEEDLE HIM GOING TO PASS UNDERNEATH AND CAREFULLY RAISE THE BLACK PARTIF THE VERIVICAS SHOULD GIVE CONTINUITY WITH EN MULTIMETRO O METER OF VOLTAGE. IF YOU WANT THE CAN BUY ALSO IN AN ELECTRONICA. SORRY ENGLISH
Cant print anymore print counting is almost full. how to reset count
try this
Manual reset methods several EPSON Stylus Color. Actually there are two methods to reset epson printers counter, that is using software resetter such as adjustment program or SSC service utility or using manual by combination pressing button on the printer. If Reset using software resetter you can follow the way of usage the software but sometimes software resetter for the printer is not available. The only way to reset the printer if software resetter not available you can use manual reset.
The Following manual reset for some EPSON Stylus Color Printers:
1. EPSON Stylus Color
Pressing and holding ALT+FONT+LOAD+PAUSE buttons combination
press POWER button
Release all buttons
2. EPSON Stylus Color 300
3. EPSON Stylus Color 400, 600
Pressing and holding LOAD/EJECT and CLEANING buttons
press POWER button and hold it until you will see blinking INK OUT and PAPER OUT leds
Release all buttons
In 2-3 seconds time press LOAD/EJECT and CLEANING buttons again.
4. EPSON Stylus Color 440, 640, 740, 460, 660, 670, 760, 860, 880, 1160
press POWER button and hold it until You will see blinking INK OUT and PAPER OUT leds.
Release all buttons.
In 2-3 seconds time press and hold CLEANING button, until all leds will blink.
5. EPSON Stylus Color 680
Pressing and holding LOAD/EJECT and CLEANING buttons,
In 2-3 seconds time press and hold LOAD/EJECT button, until all leds will blink.
6. EPSON Stylus Photo 785, 895
Pressing and holding Maintenance and Roll Paper buttons
press POWER button, You will see blinking Error led.
In 2-3 seconds time until led is blinking press and hold for 10-12 seconds Roll Paper button, until all leds will blink.
7. EPSON Stylus Photo 890, 1280, 1290
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Power led
Release all buttons
8. EPSON Stylus Color 800, 850
Pressing and holding LOAD, CLEANING Color and CLEANING Black buttons
In 2-3 seconds time press and release CLEANING Color button, You will see leds blinking.
9. EPSON Stylus Color 900, 980
press POWER button, You will see blinking INK OUT led
Release all buttons
In 2-3 seconds time press and hold CLEANING button for 10-12 seconds.
10. EPSON Stylus Color 3000
Pressing and holding PAUSE, LF/FF and DOWN ARROW buttons
turn on printer.
Printer jamed after putting in more paper and accidently pushed the power button off. Will not respond to anything I have tried.
Reset your Printer by following these steps for your Printer Model:
Pressing and holding LOAD/EJECT and CLEANING buttons, press POWER button, You will see blinking INK OUT led.
Pressing and holding PAUSE, LF/FF and DOWN ARROW buttons turn on printer.
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Error led.
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Power led.
How Do you clean the Laser scaners on a Kyocera C5025N Printer?
Open the left cover. Then grasp the green tab at the back of each LED unit, sowly pull the tab in and out about the width of the printer 4 to 5 times. This will clean the LED units. You can also use the wire cleaners at the top of each LED unit. For more details consult the operation guide page 3-12.
4helpful
Alarm lights keep blinking after I changed my printer ink.
E5 means cartridges error - to fix press the "stop\reset" button for 5-7 seconds and then release it.
You can also try this:
1) With the printer power turned off but connected to a power source, while pressing the Resume/Cancel button, press and hold the Power button.
(DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and
Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s)according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4 times----Green (Power)------Waste ink counter resetting
TV cant be switch on, RED LED diagnostic Blinks .. 3 times... then 4 times. Please advise probable cause and send sTV hcematic diagram.
Hi, this is main board failure and you will need to replace this vital board. you power board is fine but, it is unable to send a proper current through the main mother board due to the damage at hand.
Top 3 lights blinking on printer
The flashing of the LEDs you describe indicates a error. If you call the Kyocera Help Desk they can tell you what the error is based on the order and color of the LEDs. They can be reached at 800-255-6482.
Top Kyocera Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Ngoro
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
