Model: Frigidaire GPDB998JC0 It fills and drains o.k. it has stopped making it's "swooshing" sound when it washes and rinses. Doesn't clean well. There seems to be some pump function but apparently weak. it there a way to check out the main pump?
Check your water level to see if the water valve is even filling up properly. After starting the cycle, listen when the water fillup begins and ends. Open door and see if there is enough water at the bottom. Should fill up to the float valve. If there is not enough water, the valve needs to be replaced. Costs about $25 and can be replaced diy if you are handy with pushing back the hose clamp and undoing and redoing the water line connection.
Make sure you unplug the electric, and shut off the water before you even want to look behind the toe plate. Dishwashers have high electric hazard behind the toe plate..
