Compatible hard drive to replace a Toshiba MK8025GAS 80 GB
I am looking for a compatible hard drive to replace the MK8025GAS 80 GB hard drive....can you recommend one or several that can replace this hard drive in a sony vgn-s170p laptop?
You may just have the drive upside-down. flip it over and it should fit... Unless of course you got the SATA rocketfish, because your drive is PATA (ATA-6) this is actually more likely the case!
The hard drive is beyond repair. To get your laptop working again, replace the hard drive with a new one, install Windows on the new hard drive, plus the laptop's device drivers and install your programs.
Any 2.5 inch notebook hdd of the same connection type can replace the original hdd. You can check some out for specs & research at tigerdirect.com; zipzoomfly.com & newegg.com. Hope this helps.
The main factors in upgrading your drive are interface type and physical size, specifically the thickness of the drive. I haven't had any issues come up from substituting a drive of a different RPM yet. BTW I have a drive that's the same model as yours, it came from a computer that acted up like you're describing, the owner didn't worry about it, and one day it decided it wasn't going to wake up...you shouldn't have any trouble going from an 80gb to a 160gb drive.I believe your drive is an IDE interface, So just make sure you don't order a SATA, toshiba has comparable drives in either interface, I'd look for a good warranty period if the prices are about equal on the drives you're considering
