It is the alarm for your CERC SATA 1.5/6 RAID controller. Install OpenManage Server Administrator (Managed Node, from Dell's Support Site) to see which drive has failed. Test the drive using Online Diagnostics. If you cannot test the drive or if the drive fails, then replace it with a drive at least as large (can be larger) as the failed one. If it passes diagnostics, then simply rebuild the drive or assign the drive as a hot spare to start the rebuild.
It is the alarm for your CERC SATA 1.5/6 RAID controller. Install OpenManage Server Administrator (Managed Node) from Dell's Support Site to see which drive has failed. Test the drive. If you cannot test it using Online Diagnostics or it fails the diagnostics, then replace it with a drive at least as large (can be larger) as the original. You can also boot to CTRL-A during POST to the Configuration Utility for the CERC, but ideally you would use OpenManage.
