I am not able to get sound from my subwoofer. the other speakers work and i have tried a number of things. which subwoofer jack did you use and was there anything on the configuration that needs to be done? i have an amplified snell suboofer
Under the HDMI setting menu on the 605, doesn't it need to be set to "Audio In HDMI"? This should fix it.
Make sure that everything is set to HDMI and let me know if this still doesn't work
Thank you for using Fixya and Good Luck
Is the subwoofer got a power? If not then troubleshoot the input power maybe fuse damage.
if there is power, EXamine the connection from the woofer to the output of the source. check the jacket of the of termination.
