Dryers Logo
Posted on Jul 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Model 05538 - Need the 5 button switch, what is
Model 05538 - Need the 5 button switch, what is the part number? Where can I get one?
Anonymous
Level 3:
Genius:
  • Master 1,970 Answers
  • Posted on Jul 21, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1970
Questions
0
Helped
847596
Points
4702
Mcdevito75 here, Chances are only from the manufacturer, check out online at Tower fans.com Or maybe check with a Home Depot in your area for the switch.
Need the code for mobis hm 3700
I have a Kia Carnival 2005 KVII. I had to contact Kia to get the radio code and give the vin number. Note # you will only get 3 attempts.
My Kia has a Mobis HM3700 and the Code I was given is 1812.
To insert code:
1 look at the front of the Radio you will see a screen, and at the bottom of the Right hand side is a set of channel select buttons.
they look like this
1 2 3
4 5 6
Each button from button number 1 to number 4 will cycle through from 1, 2, 3, 4, 5, 6, 7, 8, 9, to 0 each time you press these buttons you will change the number on the screen.
When you have the numbers shown below
Button numbers 1 2 3 4
Numbers showing 1 8 1 2
Than press Number 5 button to accept
2helpful
3answers
How to format nokia 5200 phone
do these steps:
1) SWITCH OFF YOU CELL
2)YOU WILL HAVE TO PRESS 5 BUTTONS AT ON TIME
3)SWITCH OFF BUTTON + GREEN BUTTON(CALL ATTENDING BUTTON) + STAR (*) + HASH (#) + THREE (3)
4) IF IT IS NOT WORKING THEN GO TO THE FOLLOWING ADDRESS
5)ANDHRI (WEST), BONNY PLAZA THERE ANYONE CAN FORMAT YOUR CELL IN Rs.50/- ONLY
2answers
Lost my FOB I have a new one but I cant turn the alarm off, I called harley and they said to turn on the bike and immediatly push both left and right blinker buttons, Ive done this probably 30 times and it...
OK so here is your solution. from your dealer when you purchased your bike with the alarm system you were given a 5 digit pin number. in order to turn it off manually you need to unlock (if locked) the switch, turn it to accessory.
push both left and right blinker buttons in
with the left blinker button is you "digits" so if (ex 56726) push the left button five times
to go to the next button push the right blinker one time then left six times
the right blinker one time and left blinker seven times
then right two times right once
left six times and right once. this will turn off the alarm
to program the fob you need to turn the ignition switch in a sequence of
on off on off on
with the blinker buttons you push
left left right left and your signals will flash the hazards twice
push and hold the fob button till the hazards blink three times and you have just programed your fob
push and hold your fob to set alarm and double click to disarm your alarm
I need the programing codes for my RCA tv. Model number d52w20. Trying to program my direct tv remote to it. Thank you.
11447
Setup Instructions
  • Set the "Mode Switch" to Device 1.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the 5 digit Code above.
  • Try your new code and tell us how it worked!
  • 0helpful
    2answers
    When the computer on/off button is pressed , the CPU fan and tower exhaust fans start running, the blue light around the power button does not light and the boot up process goes no further. Fans continue...
    A) When you hold a Power On button, (Switch actually), in for a count of 10 seconds, it turns the computer off.
    (There is a Power On switch, located behind the plastic Power On button. Usually, the Power On switch snaps into the housing of the plastic Power On button.
    Example of a typical ATX Power On switch,
    http://www.directron.com/atxswitch.html
    The Power On switch turns the Power Supply on.
    Old computers had a metal rod, that when the Power On button was depressed, the button pushed against the metal rod, which in turn pressed against a power switch located inside the Power Supply.
    The design after that, was a power switch located in the Front Panel. (Plastic front of the computer) A large cable, (Wire) ran from the switch to the Power Supply.
    Now there is the Soft Power On feature. (PS_ON)
    The Power On switch is a small Momentary Contact Switch. Pressing it closes a circuit. The Soft Power On circuit.
    When a power supply is plugged into power, there is a constant 5 Volts (DC) present.
    This is the 5 Volt Standby.
    Closing the Soft Power On circuit, redirects the 5 Volt Standby power to a circuit within the Power Supply.
    This in turn 'excites' the Power Supply, and turns the Power Supply on.
    Sorry to be windy, but I wanted you to know how the Soft Power On feature works )
    eMachines are a budget computer. As such they save the consumer money.
    However in order to do this, the manufacturer will install low quality parts, in some areas of the computer.
    One such part is the Power Supply.
    1) ALL the LED lights combined use less than 1 Watt of power.
    2) EACH fan uses 2 to 3 Watts
    3) A typical Processor can use 51 to 125 Watts.
    Depends on what Processor it is.
    (Had you stated the Model Number I could have told you)
    Enough power to spin fans, but not enough to spin fans, AND turn the Processor on.
    Do you have access to another computer that is unused, but has a Known to be good, Compatible power supply?
    It could be used for a test unit.
    Tell me the Series, and Model Number of your eMachines, and I'll tell you what Wattage it should have, and what power cables, for the Power Supply.
    (Some examples of Series, and Model Numbers, T1090, E4264, W2925, and so on. The T, E, and W are a few examples of the Series letter.
    The numbers following the Series letter, is the Model Number)
    If you wish I can direct you in removing the Power Supply, and installing the test unit. (And/Or a new Power Supply)
    Light and turntable stays on
    Chances are you have a bad bottom door switch or a misaligned bottom door switch mount.
    We have the service manual for this model and have uploaded it for you here. The separate parts list (if needed) is here.
    Also see our file on door switches here.
    If you only need a switch, you can order a universal type here for $5 postpaid.
    If you need other parts, you can order them by part number here.
    1helpful
    Squeak in aloha breeze tower fan model 05538
    If the model is equipped with a fan, and the noise occurs even when not oscillating it must be a fan/blower motor. If it is a squeak. A squeal could be an electical component going bad which is always bad. I would definitely take some bottom drawer tools , ie. screwdrivers and WD-40 and oil that squeaking motor. Being a fan it goes through alot of air pollutants. That tends to build up on the shaft and can work its way into the bearing seal. Good luck.
    Dryer runs for 2-5 minutes then shuts off.if you hold the start switch on then it runs but shuts off when you let it go
    When you have to hold the start button to run the dryer you are doing the job of the motor centrifigal switch. Initially you press the button and the motor turns over closing the motor switch so it will run and heat to dry your clothes. These days that switch is not replaced, only the motor. So you need a motor and I will be happy to find you one if you can supply me with a model number.
    Searstechtoo
    Sep 13, 2008 • Dryers
    3helpful
    3answers
    Aloha Breeze Tower fan remote control no longer functions consistently. A replacement remote control is needed, or this one needs to be fixed. Is a purchase of a just a remote possible? Suggestions?
    I'm serious even though it sounds like a joke.
    Call 1-800-REMOTES
    or here is their site
    http://www.remotes.com/store/aloha_breeze/84001.html
    Aloha Breeze 84001 Remote for $28.95
    Shipping in US and Canada is $7.95
    Hope this helps!
    Top Tower Dryers Experts
    Jay Finke
    Jay Finke
     Mikey
    Mikey
    Virgil Watts
    Are you a Tower Dryer Expert? Answer questions, earn points and help others
