The defrost thermistor is your problem: it is going low (turning off) the defrost circuit far too quickly; it is a solid state version of a gas filled cold control sensor.
It "tells" the adaptive defrost controller circuit board the condition: (frost level) of the evaporator and, intitiates the defrost mullion heater timer. if it turns off to soon defrost
mullion heaters turn off and, icing occurs. I do not know; right off hand: which boards you are alluding to; however I believe you are referring to the power supply board for the
Testimonial: "I will let you know after replacing the part if it fixed the problem. I tested the thermister at 32F and it shows no continuity(infinity). Many thanks"
Its defrost problem, the freezer should cool,
then freeze, then defrost cycle should start. In your case freezer is cooling,
then freezing, but its not defrosting. That's why fridge section is not
cooling.-------
Click this link below and follow the
troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator and why it is not cooling
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
