Feb 20, 2011 - These codes in your (made-by-Samsung) Maytag washer might pop up during the ... In fact, the E3 error code means that the Machine Control wants to make the motor spin but won't do it because it's getting a weird reading from the tachometer.... MAH6700 and MAH8700 models (they use the same motor).
May 15, 2015 - Samsung uses the 3E error code to indicate a drive motor tach fault. ...If you're handy, you can fix your Samsung front load washing machine error code ....My samsung frontload washer shows e3 and the drum does not turn ...
http://homeguides.sfgate.com/maytag-neptune-washer-model-mah8700-troubleshooting-codes-102595.html. Here's the site for Maytag Neptune Washers. You can also find other modes there. Hope this helps. Enjoy.
If the clutch fails the first thing noticed is a UC or DC error displayed and there is no drain or spin.
If you are seeing the above error and having a problem with spin and drain then the most likely cause of this is the clutch. The clutch fails to lock down the spinners and the basket is unable to go into spin and without a 90 RPM there is no drain.
Replace the clutch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$#$
Hiya bcd1...what model number? see below info.. is yours one of these?
The front loading washing machines have been known to leak water onto the electrical connections to the machine's thermal sensor, which could cause an electrical short and ignite a circuit board, causing a fire.
The recall covers 250,000 Maytag washers and 20,000 Samsung front loaders.
Maytag machines affected have model numbers beginning with MAH9700 or MAH8700. The Samsung washers have model numbers beginning WF306BHW and WF316, although not all serial numbers are subject to the recall.
